The 95 model only got driver's airbag and no passenger airbag, is this correct?
I think the AFM has a sticker on it with different colour between S1 & S2. Not sure which colour is which series... I was told the coil packs are also different.
S2 turbos are different, they spool up faster.
A lot of people say the s2 turbo is not as good as s1 tubo, due to a plastic compressor wheel, but unless you intend on increasing the boost more than 10-11psi, in which case s1 & 2 turbos would have limited life, series 2 probably less life, that the plastic wheel is better. Its there for faster spool up, therefore the engine is more responsive.
Even the r34 gtt has a 'nylon' wheel. As read in speed magazine(current). So i dont see why people bag the s2 turbo. Some people say it was for cost cutting, whereas it seems logical to me that it was an improvement, that nissan spent money on.
But yeah, between a s1 n 2, get what u think looks better(interior especially...i think the s2 dash is much nicer) if u have the $$. If not, get what is cheaper, they are very similar.
The series 2's are newer of course and easier to find with options on them like ABS and dual airbags. However the 95 model released just previous to them has the same options available.
The series 2 is a slower car than the 95 by all accounts due to the later ecu map being more environmentally friendly I guess. The quickest standard cars at the moment are all 95's I think, running standard turbo's and ecu's.
If I had to get another R33 I'd get the 95 again for sure.
So ur sayin if i saw a 95 ecu for sale sumwhere cheap, it would be a good upgrade (till i shell out sumtime in the future for a powerfc)?
never knew this whole 95 1.5 series business... learn something new every day...
I dont think skylines are rare..especially in sydney. Guess it depends what your definition of rare is....try last night, george street...must have seen at least 15-20 in 1.5 hours lol.
nah siksII, although there are a lot of skylines in George ST, beware that it isnt the same person, coz last time i saw this guy in a white Series 2 skyline near hungry jacks turning. Then afta that i saw him another 3 times in a 1 to 2 hr period..
some pplz jus like to do happy laps and have $$ to waste on petrol. Or it could i was wrong and he was looking for a parking spot for 2 hrs..lol who knowz?
    • In the US almost everything is E10. It can't exceed 10% by much or fuel systems have trouble adapting. At the same time because MTBE, MMT, and TEL are all banned they need as much ethanol in it as possible to boost octane.
    • I was mostly jesting. In my experience (and probably only my experience) the R34 GTT physical airbox space is actually too small to flow the amount of power it wanted. By sealing the box, I made it so it could only be fed by the ducts themselves. So you can seal it up and get nice cold air which IS good, but at a certain crossover point: More Hot Air > Less Cold Air I don't think you're at this point. In my case merely ducting the hot air intake with a very focused set of ducts counteracts the fact it's in a V8 engine bay. More cold air obviously best. The solution looks great.
    • Nah, the OEM CAI pipe is still installed behind the bumper, it is about 5" x 3" oval at the engine side, tapering down to a 3" pipe behind the bumper where it gets all the ambient air it needs Engine side of radiator support OEM intake pipe "oval hole" that is right in front of the filter My OEM NC1 CAI pipe: From NC2 onwards, below pic, they come slightly smaller at 2.75" diameter with corrugations and a resonance chamber to reduce intake noise, lucky for me my NC1 has the bigger noisy one, LOL   Basically, the "sealed" airbox will just get ambient air from a 3" pre filter intake tube that is the same size, 3" as the rest of the intake pipe post filter, and if a 3" intake isn't big enough to flow enough air for 150 killerwasps then there are other issues The whole intake is basically the same length as OEM, but it is now about 30% bigger from the airbox back through to the new intake plenum than OEM, and the intake plenum is port matched to the head And the intake is now about 30% bigger than my 2.5" exhaust, so the suck, squeeze, bang and blow black magic should be fine, well, to my uneducated understanding of fluid dynamics anyway Talking the the guys at MX5 Mania, it may even make a few more killerwasps as the intake isn't sucking hot air, especially off idle or when in slow traffic when it would be sucking hot air  As for the difference in IAT, I haven't logged IAT yet, as I don't currently have a OBD2 reader, but I will have a play with my thermal lazer thingie next time I take the car out to sèe how hot stuff gets under the bonnet near the intake filter prior to installing the air box, my "assumption is it has to be much better after the air box is in and sealed up compared to what it is now The aftermarket "performance" CAI elephant in the room: Aftermarket CAI intakes typically have the air filter tucked up behind the bumper, with a 2.5" intake tube (the OEM intake pipe is actually about 30% bigger than the fancy pants "aftermarket" version.....WTF), and you need to remove the bumper to service the filter, which is a PITA Like dis:
    • Nice one, I'd argue that the white S1 RS260 is certainly the best looking of the Stageas. And yes, fully agree on the forum situation. It's a bit of a shame, but at least SAU is a good place to be. I found the facebook groups to give me FOMO because people were trying to one-up each other and show off in some way. Feels much more natural here. There are people with seriously nice builds, but I can appreciate it rather than it making me question my life choices. Might be that people are more open with sharing how much work/money/suffering it takes to actually get there.
    • Evening, wanted to pop in and finally register to say hi to everyone here on SAU!   It's been a while since I've been active on a forum, but back in the day I used to be relatively active on ClubLexus and other hobby-related forums. I'm glad to see SAU is still around, since with the advent of Facebook and Discord it seems forums aren't what they once were. As a recent new owner of an S1 260RS Stagea, I've found so many older guides and helpful tips from SAU that I figured I needed to join and say a grave thank you. My recent acquisition has only become legal in the US for the past year, and knowing that similar car enthusiasts from across the pond have already figured out the kinks and tricks to get these 25+ year old cars running well. I look forward to diving into more of the SAU forums as well as hopefully contribute some info myself for future posterity.   As a pic tax, here is one of the few good photos I have of my Stagea. I hope to get way more in the future!
