Vband makes it quicker and easier to remove the turbo as you dont have to screw around with the nuts that can be hard to get off after a while
other than that I dont think there is any real benefit - looks cooler!
https://www.sau.com.au/forums/topic/221108-flange-or-vband/#findComment-3898404
V-band is much better. easier to position, better sealing, does not leak when hot, ummm easier to take on and off. you should use them everywhere that is possible! even for your exhaust joints if you have the $$.
that is the only downside to B-band I know of. Cost. they are much more expensive than traditional flanges.
https://www.sau.com.au/forums/topic/221108-flange-or-vband/#findComment-3914472
i find my vbands on my tial gate screamer pipe and one on the hks t04z turbo to exhuast both leak from looking at them when removed, i have one further down the exhuast and that doesnt leak, any ideas to stop them leaking? they fit up perfect so its not like the fitment of the exhuast isnt right.
https://www.sau.com.au/forums/topic/221108-flange-or-vband/#findComment-3914903
they shouldnt leak unless they are warped badly or have high and lows somewhere along the rings that is stopping it from sealing completely. But normally v bands are an excellent and bulletproof way of joining pipes.
I love them! All turbos should have them for exhaust in and out, would make it so much easier to fit and remove...plus neatness!
https://www.sau.com.au/forums/topic/221108-flange-or-vband/#findComment-3916705
  • 4 months later...
  • 1 year later...
Ever sorted out this issue bro???
I've heard they seize up after a while as well
Any reoccurring probs with vband style flanges??? My concern is with the sealing.
https://www.sau.com.au/forums/topic/221108-flange-or-vband/#findComment-5011147
i am assuming they are only leaking when cold and when warmed up are fine. I never hear a leaking noise or anything so it doesnt bother me. The car never got drivin often and was taken off the road shortly after so never really fixed it.
https://www.sau.com.au/forums/topic/221108-flange-or-vband/#findComment-5011702
I've got the same thing...
I think The major advantage of V-Band connections off a turbo would be if ur dump goes straight into a bend... like mine...
I have nuts on mine and have to work the dump pipe off while i undo one of the nuts...
https://www.sau.com.au/forums/topic/221108-flange-or-vband/#findComment-5015710
they are interchangeable just need the right diameter... not that expensive really i paid $10 each for the v band itself and the rings to weld to the pipework... my tial ext. gate, and 4 v bands on the exhaust...easier to take on and off and easier to work with in confined areas...
https://www.sau.com.au/forums/topic/221108-flange-or-vband/#findComment-5018286
Speaking of v-bands...
Just been working on the exhaust system.
Unbolt the downpipe from the rest of the exhaust to get a piece of the exhaust out to weld the resonator into.
Hmm, the downpipe connection onto the turbo exhaust housing seems a bit loose or something.. *rattle* WTF the dump pipe just fell off the turbo! *takes the turbo 'beanie' off* WTF there's no v-band clamp on the v-band connection, IT HAD BEEN WELDED ON!! D: I have no idea how long it has been broken off like that for since the dump pipe connection to the rest of the exhaust would've been holding it in place, but it would've been leaking like mad and still is! Gonna organise a v-band clamp now, luckily the exhaust housing isn't broken! Only the weld.
In the pic, exhaust housing to the left, dump pipe hanging down on the right, you can see the broken weld on the turbo.
https://www.sau.com.au/forums/topic/221108-flange-or-vband/#findComment-5030671
How far back is ur 1st exhaust mount??
Could have been caused by having to much weight hanging off the turbo...
https://www.sau.com.au/forums/topic/221108-flange-or-vband/#findComment-5031556
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
