Hi all.
Heres the thing... My oil pressure on my newly rebuilt rb25det s1 engine is wierd... happended suddendly.
when cold 100psi at idle, when 180F its juuust under 25 psi idle 800 rpms. This is good as far as i know.
I will use a scale from 1 to 10 to simplyfy "acceleration" here in my example. 10 is full throttle
But! When accelerating, especially in first and second at say 4 ish, oil pressuere suddenly fall of! it just drops, both my std oil pressure sensor and my autogauge oilpressure is doing it. shift into 3rd an give more throttle, accelerting at say 6, I can feel mere acccel. it doesnt drop of, I can floor it, it stays up, sometimes dropping a little..
I have just run in the engine over 5000 km, and have given more and more gas and revs. havnt noticed anything like this! and have accelerated on full throttle, just one morning this issue!!! Im not 100% sure, but i THINK it was after a night with alot of rain and wind.
Have tryed WD40 on my connections.
My worst thougt is this is something mechanical... If oil pump is on its way does it do this?? what mechanical thing could do this?
If i just rev the engine no drop of in oil pressure. Have also tryed filling 1 liter oil more on it.. no change.
Can anyone help?
https://www.sau.com.au/forums/topic/221884-wierd-oil-pressure/
its a sudden thing this issue!... it happend over night...
and have given much more gas than what it takes to make the pressure drop now..
but, im fitting a mechanical oil pressure gauge, and will see if pressure drops.
Well, the oil pressure is something mechanical... hooked up a regular gauge and it does the same.
So any suggestions were ill go fróm here?
Will try and remove oil pan to check the oil pickup. Anything else while im there?
dont risk it with the oil pump, i nearly lost my forged engine because i was using my old pump.
Got a N1 pump and now its fine. if anything it has too much oil pressure. We changed mine with the engine still in the car. was a pain in the ass to do too.
So it happens when its on mid-throttle?
Youve probably already done this but checked your oil-level? Or else it may be the oil pump.
Did you get a new one put in when the engine was rebuilt?
Have you checked your oil level??? If the problem is associated with acceleration, my first check point would be how high my oil is....
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
