The 0.68 would be "snappier" as it runs into boost, with an earlier/faster rate of acceleration of the rotating assembly. The 0.87 may result in too slow a rate of spool but certainly give the feel of making lots of power higher up.
Bit of a juggling act to get sufficient bottom end response and torque from the smaller cubic capacity engine, but allow sufficient mass flow through the turbine housing to not choke things higher up as revs and power output rise.
Dependent on what other mechanical modifications are made (manifolding, porting, cams), the 0.68 might prove to be the better match to give area under the curve. Focus on the torque curve.
Edited by Dale FZ1
My opinions only , take them or leave them .
To me a GT3037 seems like a lot of turbo for a 2L six , some even think they are a bit ambitious on an RB25DET .
If I had to run a 3037 GT Pro on an RB20 based engine I would opt for the smaller or 0.68 A/R turbine housing .
Depending on how much power you realistically expect to make maybe a HKS GT-RS would be a better all rounder in a street car - definately cheaper and easier to fit .
A turbo car doesn't have to break into wild wheelspin as soon as it comes on boost , I reckon that's more an issue of the transition of no boost to too much boost over a narrow engine rev band . If you can get it to make adequate boost initially and ramp up a bit with engine revs you may find the lack of traction less of a problem .
A .
sry disco but im aiming for 400rwhp ive got an apexi ax53b70 in there atm and thats around the same as the gt2535 so an upgrade to the gt-rs is not worth the money imo an rb20 is going to b laggy no matter what so i think im guna go 4 the .87 will post dyno results when car is done cheers boys
Edited by Justa32
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
