well not much work on the car today, but we sure weren't bludging around.
firstly loading up the 200 odd possum traps fresh from the china container into the truck to make space for car bits.
then pulling most of the car parts out of the garage....
if anyone needs 3 HICAS racks we are the guys to call lol
oh and we got the gas burner started after it's rebuild too so that is the first new motor for 2009. just running on petrol, the gas install still needs a little work to finish off
After what Neil did to his finger last week, I don't care the the gloves make me look like the tooth fairy.
All that stuff was a bit depressing. I was starting to think that the other race car might not be too far away, but seeing it all piled together I see how much still needs to be done.
Still some issues with the gas guzzler. Still have oil burning problems, even after the rebuild, so there's something else wrong. Could be head, which sounds very tapety, or maybe the turbos, though there was no evidence of an issue with either when they were off. May be up for a new head or head rebuild right quick!
Yep, cheap quick and nasty rebuild. Worn race engine that had bad oil scraper ring and the head had already been rebuilt so I left it. My mistake so now I'm going to pay the piper. Fortunately the seals can be changed without removing the head, apparently. New skill to learn.
Does it somke much out the exhaust on acceleration? or does it somke when not acceleration down a hill, ie using engine brake?
true that.
Seals can be done with the head on. I have a specificly made tool for changing them if you need it. Just need to bolt the tool down where the cam caps normally go and put compressed air into the bore to hold the valves up when the collets are taken off.
haha you're asuming its been out of the driveway :) plus why would it need new valves seals the current ones have only done about 8,000klms :(
you guys really need to take this thing for a drive before you get to carried away.
Been for a drive up and down the street and will take it for another tomorrow. It seems to smoke some after a few minutes of idling on start, but not when driving. Head does sound very tappety though, more than normal. Smoke is not very pronounced, but it's there for a newly rebuilt engine, even for a cheap and nasty rebuild.
Prior to the rebuild, it used to start smoking at stop lights after I'd been driving for about 15 minutes and go away when driving.
Can we not talk about my finger,,,it still looks like absolute shit. Gloves are now my best friends,,,I'll take pink or purple any day.
I was a little more productive today,,,removed my cv's thanks to that great new tool Mark.
Neil.
yeah well believe it or not I'm no race car chassis designer :P but my understanding is that uneven length double wishbones are the optimal setup for front or rear....the only real difference normally is the driveshafts in the rear but I guess you've already alllowed for them at the front. If you look at any proper race cars like Neils they just have the same or similar setup at both ends.
I guess one thing to think about though is the difference in arm length top and bottom. if you aren't using standard lengths the dynamic camber gain must be different - and assuming your new top arms are longer you will get less gain (=more static camber required = braking and stability impacts)
Re the bump steer - the current setting is about where the hicas rod sits, so it will not be right (the control arms have moved up but the steering arm hasn't). Since it is easy enough to move the inner end (and we use standard outer end), we can just measure it up once everything else is finshed.
BTW looking forward to those windows :P if you haven't got the materials yet can you grab 3mm for ours. I'm hoping that will be enough once the window frames are in.
i know i haven't posted in this thread yet but do you have any more info on how to change the mounting points or is that a bit of a secret between mates?
i have a R32 GTSt and i have read that a r34 rear cradle is a good upgrade for traction as the control arm mounting points are in better positions geometry wise. is what you have had done similar to running a later model sub frame?
thanks for any help you are able to give me.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
