  • Replies 44
why? you do know that that kind of stuff is made from recycled old oil!
ive spent alot on the build!!! money for oil is not a problem....
i have just been told so many differnt things.....
Penrite make a good "run in" oil...hang on ill do a search
EDIT: here ya go...
http://www.penrite.com.au/html/s02_article...p;nav_top_id=55
Valvoline make one too...but i just use a mineral based Valvoline with no friction modifier.
Edited by DiRTgarage
its one to think about... should it be ran in like they say to as well?
as i have heard 500km will do then a oil filter oil change...
i generally drop the oil and filter after a few hrs or 100klm.
I change the first oil filter after 10 to 20 minutes running. New oil filter and top up the Castrol GTX. Do 500 k's, usually to Bathurst and back, lots of uphill stuff to load the engine. Check the leak down, if OK then change the oil filter and oil to Castrol Edge 10W60.
Cheers
Gary
well im not bout 2 months off starting my motor which is a tomei stroker motor with almost everything tomei which we all know is worth a pretty penny... so gtx still cheap but will do the job just fine its a 20w-50 isnt it..... wouldnt ya want sumthing a lil bit thinner to make sure it penetrates everywhere.... provided clearances are all correct it shouldnt matter but yeh im just curious as to this matter...
off topic wat do u guys do for a run in technique nethin special or unique???
Edited by skylinekid
My motor got 20 min run in on the engine dyno with basic synthetic oil, then map low end then full throttle!
riteeee from wat ive always been told u should never run in ur engine on ne sort of synthetic type oils due to they can glaze the bores hence shit sealing of the ring which makes for an unhappy engine.....
so yeh hows it runing these days???
Sorry my mistake, that was supposed to be "basic mineral" oil
I used the castrol GTX as someone said earlier in the thread.
Edited by GTR1993
Cheers
Gary
just curious on the way the car gets driven to bathurst, revs etc or do u just drive normally and let the road do the work?
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
