  • Replies 61
start adding it up
5-6k for engine
1-1500 for box
new tailshaft and all lil extras to get it happening
oil,fliters air & oil , coolant, new clutch adaptors for pods
pimp carbon fibre bonnet (optional)
SH*T it adds up quick. less the bits you can quit from your car.
