Hey all,
Just thought I would write a quick one on how to disable the Rich and Retard function on the stock R33 ECU by disabling knock sensors...
Disclaimer: Do not do this unless you understand what detonation is and what causes it. Basically it involves disconnecting the knock sensors and fooling the ECU that they are still there. I have done this modification because I am running forged pistons in an RB30 block and had concerns that piston slap on cold starts 'may' have been mistaken for pinging by stock ECU and therefore ECU keeps using R&R maps...Also the stock ECU would be very conservative wrt to knock detection and tuned for the acoustics of the RB25 block and not the RB30..
If are running stock RB25 there is no advantage in doing this and you risk f**king your engine....Don't do it...I have written this post just out of interest
First off R&R is triggered by engine knock and not excessive airflow. Airflow cut is is completely different and doesn't revert to R&R maps...R&R maps and R&R mode is a protection against bad fuel and once the ECU goes into R&R is slowly creeps ignition advance and leans back the AFR over time.
'Airflow cut is always active and actuates as soon as afm voltage exceeds a certain threshold. It is a constant and cuts ignition when the threshold has been exceeded...as soon as the afm v drops it brings back ignition...there is no learn/relearn function once it has been triggered'.
Now for how to do it:
If you just disconnect the knock sensors the ECU gives error code 55. When ever this happens the ECU reverts instantly to R&R anyway...Also if you ground the Knock sensor signal wire it also goes to error code 55 which again reverts to R&R mode...(maybe a few people reconnecting their knock sensors about now)...
The only way to do is to make the ECU 'think' that they are connected. The resistance of the knock sensors is about 500kOhms at DC. So what you do is disconnect the knock sensors and put 500kOhm resistor across the knock sensor input and ECU ground...On R33 ECU knock sensor inputs are pins 23 and 24. Check the picture for how I did it internally. I have actually used 2 1MOhm resistors and tied the two pins together and grounded them to the ECU chassis...
You should not really do this mod unless you have Nissan Consult gear. Then you can check you have done it the right way and not caused any errors.
I set ignition timing as per normal way but have worked out how much extra base timing I can run without excessive knock based on the all of the other mods I have done...It is no substitute for aftermarket ECU and good tune but I am happy with the 277rwkW I have been reliably making for the past 2 years with the stock ECU...
Nice work man.
So the extra engine noise of a modified engine over stock triggers R&R not the extra airflow, tha be right?
Bloody good thinking and thats got to be a record amount of power with a stock ecu. :)
Nice work man.
Depends on what you mean by modded engine...If you run forged pistons the extra slap when the egnine is cold 'may' (and I say may here cause I haven't measured it) be seen by stock ECU as detonation...It shouldn't be a problem if you run cast pistons....
And yeah the extra airflow will cause ECU to drop ignition which is very noticable...It starts by dropping alternative spark and if bad enough will cut ignition right out until airflow drop below certain level...If you keep on the throttle it will stutter (like on rev limiter) because highairflow causes ignition cut which cuts engine, airflow drops, ignition comes back, airflow comes up again, ECU cuts spark and so and so....
1)... why wouldn't this be usable on a 25? if you can disable R+R surely this must enable more power...
2)... why not just use this in conjunction with an aftermarket knock sensor and knocklight?
once the engine warms and piston slap stops
would not the stock ecu stop R/R ?
YES and NO....the ECU stops R&R gradually...its function is to protetct against bad or low RON fuel so it once it is triggered it kind of goes into a learning mode when it brings back fuel and ignition parameters very slowly...
reseting ECU brings it back straight away but I think even then the maps are a little conservative...Not sure on this...never tried to measure it...
Because if a stock RB25 ECU is running a stock RB25 bottom end and the ECU is detecting pinging, the engine probably IS pinging and R&R will save the engine.... piston ring lands are the achillies heel of the RB25...
Hi Paul,
What parts are you using to make that power? I realise it's a rb30 but what turbo etc? Are you using any other piggy backs with the stock ecu?
Cheers
Turbo is GT3076R...Airflow cut is managed by playing tricks and games with boost curve which is done by camshaft timing....and other things...
ahhhh Dr Paul up to his usual engineering tricks....
;) long time no chat
Ahhh yes Dr Power FC how are you??...Hey when we did that power run I hadn't yet done this mod so it may have been in R&R to some degree...
I might be on the dyno again this weekened if i can get all my mods installed on time.... PM me your phone number cos i lost it and if i end up gettin the dyno i will let you know...
It did feel like it was breaking down a little, i figured it was spark issue... could have been r&r as well. gap your plugs to .7 and lets chuck it back on ;)
ohhh and im good.. i got quite a few more mods done to the beast... getting her ready to race!
Yeah I took the plugs out and they were copper, a bit tired and gapped to 1.0mm. Put in some Brisk plugs and gapped them at 0.7mm so Im keen to see if this fixed it...From what I know about R&R it is fairly slow to react and certain doesn't jump around...I think on a dyno you would just see richer mixtures and over the whole rev range and wouldn't look like break down typically does...Anyway
Are you going to Wakefield on the 21st June??
yeah thats why i suggested its the plugs.
It would be interesting to see if you can break the 280rwkw mark! damn that would be cool.
I don't think i will be going to the track days just yet, i need to sort my car out and make sure its all reliable and setup right before i go do any racing. I need a few weeks.
Interesting.............I have a a question though. If excessive airflow on its own doesn't activate R&R why do I see rich A/F ratios and retarded timing on the dyno even when there is zero knock? The Stagea suffers from this on cold days. I run 100 ron fuel (Shell V Power Racing) with the SITC retarding the ignition and so there is no knock that I can detect, but the A/F ratios drop from high 11's down to low 9's and the ignition retards 10 to 15 degrees. Maybe the ignition cut can explain the richer A/F ratios due to the resulting unburnt fuel, but it doesn't account for the retarded ignition. The R&R isn't as severe as when there is knock, but it's still there.
Cheers
Gary
From what i have read on here of your setup, there are two factors playing here. IMO this mod is only preventing your ecu from dropping into the low octane(knock) map. R&R is basically cells in the mapping that do exactly that, and when you increase the airflow(at relatively low/mid rpm's it hits these cells. Coincidently these cells are where the knock detect is enabled, where it isnt at the higher rpm's. IMO there is another function in the ecu which detects excessive AFM voltage rise rate, and also exhibits similar traits to R&R, which is what results in the sawtooth power graph you see when you turn the boost up on a stock ecu.
Have you tried having the knock sensors on a switch, so they can be off when its warming up, and then turn them on once its warm. I believe it wouldn't change your power output, as its your other tricks that are giving oyu the power. As SK said this is merely fooling the ecu into believing there is no knock, so if there is no knock, in theory there should be the same outcome.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
