Hey I got an automatic R33, wanna know if anyone has changed their automatic shift knob.
If so what did ya do to the overdrive wire that was connected to the original factory shift knob
and do I need to buy a shift knob with an overdrive button?
Thanks In Advance
https://www.sau.com.au/forums/topic/222426-shift-knob-for-automatic-skylines/
Dont know why you would change it unless you are going manualised auto? most ppl who do that go a b&m style ratchet shifter, but that means cutting the console etc to fit it.
as for the overdrive button, just rewire it to a switch or push button and mount it near the shifter somewhere. you can buy addons for some of the b&m shifters that have an overdrive button in them. could be hard to find.
there was also a topic on here somewhere ages ago where someone sourced a different shifter for an auto out of a 300zx or something similar, looks a bit more sporty. kinda similar shape to r34 tiptronic shifters. check ebay maybe?
i got a magic stick in the ceffy, its a non t-piece style auto shifter with the overdrive button. bought it in japan... was like $30 bucks. Haven't seen anything even remotely similar available locally, at least not with the overdrive button and gear release buttons.
There's also the Navan shift knob which is pretty popular with 300ZX drivers. I had one of those and sold it for $150 a couple of years ago. Again with the gear release and overdrive buttons.
unless my job does not involve driving through the CBD
I think I'll stick to my automatic
as I don't want my hands all sore when I get to work at peak hour
I still have fun shifting to neutral when coming to a stop
yes 1 to make it look like I'm driving manual :( and 2 to save some petrol
thanks Basti I'll have a look at that
Haha hands sore from driving... wow harden up cupcake
I found it on the US eBay site (www.ebay.com)
Jet Pilot Auto Shift Knob
I was looking at that last month, but still haven't got a reply from them yet.
I asked if it woud fit our GTT's.
Don't think there gonna reply, let me know if you go ahead with it. i just want to know if it fits.
Yahoo Auctions Search for Auto shifters with overdrive. Contact Laurence to grab one (would be cheaper than buyin the same thing off some leprechaun in the US who imports it from japan to sell on ebay).
  • 1 month later...
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
