Hi,
Im just wondering if any of you know what the spring rates of standard R32 gtst M spec springs are.
Also, does anyone know what the rates of the Whiteline springs in Sydneykids group buy are for the same car?
Im having traction issues, and was wondering if it would be beneficial to replace the rear Whiteline springs with standard springs, so that the car squats a bit more. Gary suggests that rear springs of no more than 3kg/mm are suitable for 'tractionally challenged' rear wheel drive set ups, but i have no idea what the rates are (and SK's inbox is full). Busy man i suspect.
Thanks for any help.
Shaun.
PS: While im here, ill throw this one at those who care.
My car sits about 8mm higher on the passenger side than the divers side front and rear. Its always done this, but i installed the whiteline kit yesterday, and its still doing it. Previously i had whiteline springs on standard shocks and sway bars, but yesterday i installed the bilsteins and bars to go with the springs i already had.
Im just wondering if i should worry about this and even change the height of the drivers side (bring it up one circlip groove), or just leave it alone.
Thanks,
Shaun.
When you say uneven, is that measuring from the centre of the wheel to the top of the wheel arch? I know mine were slightly different left-to-right, but that was because my guards were rolled and were uneven.
Hi mate the std spring rates for a R32 Gts are 3kg front and 2kg rear
I beleive the SK groub buy are 3.5kg front and rear can be wrong
anyone confirm this? Your traction problems can be your tyres have
gone off or maybe your wheel alignment settings to much rear neg camber
With the car sitting higher on the passenger side even after the new
suspension set up check to see if the guards are the same measurement
where on mine we found that the front drivers guard was 5mm different
than the other side.Good luck
Thanks mate.
Ill measure from the ground to the guard on either side to see if theyre the same. Probably should have done this before, but the car is mint, so i cant see it being out by that much.
Can anyone confirm these spring rates?
Shaun.
Its kinda normal, spring manufacturers work to 5% +/- tolerance IIRC,
Which can add up to a reasonable difference, but it can be compensated for.
Call into a suspension shop, they should be able to even it up for you.
Hi,
Shaun.
Thanks,
Shaun.
Hi Shaun, the standard spring rates are around 3kg/mm front and rear and the Whiteline springs are around 20% to 25% higher. Not enough to make a lot of difference compared to the effort required to change them for drag racing, you would be much better off using the Rear Subframe Alignment Kit on the Maximum Traction setting. The other worthwhile trick is adjusting out the negative camber on the rear. We have found around 0.5 degrees positive camber is a good place to start.
It is not unusual for the RHS to be lower than the left, most times the car has just the driver in it and takes a set to the right over time. For height correction, the method I use is to measure the heights on all 4 corners then adjust the lowest of the pairs up the necessary amount. That is usually the RHS rear, move it up one circlip groove. That will lift the RHS rear 8 mm and lower the LHS front around 3 mm. See how that would work against your current measurements.
Cheers
Gary
Cheers
Gary
Thanks for your relpy Gary.
Ill keep the springs in then. My next move was to fix up the rear camber, as you suggest. Ive been told that the skylines do have rear camber adjustment as standard, so does that mean i dont have to purchase a camber kit? Also, do you sell the rear subframe alignment kit through your group buy? What does it include and how much is it?
Ill adjust the heaight in the next few days. I just wasnt sure if it was bad to have the springs under different loads on the car, but i suspect that 8mm wouldnt be significant.
Thanks again,
Shaun.
Thanks again,
Shaun.
Found prices for the camber and sub frame alignment kits. Im still wondering what the subframe kit consists of and whether i can fit it myself.
Also, if im aiming for a height of around 335 - 340mm at the rear, will i need a rear camber kit or is there enough adjustment to get between -0.5 and +0.5 in the standard set up. Thats if there is any rear camber adjustment in the standard set up; i dont know yet.
Any help is appreciated; i need to get this set up and no-one around here knows shit about skylines.
Shaun.
Shaun.
Hey mate, the alignment kit is easy as to fit. You only need a jack, stands and hand tools. I did mine while changing shocks and swaybars so im not sure exactly how long it would take by itself. But id guess 1.5 hours max to do it yourself.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
    • I'm extremely suspicious of the VPP stuff. Best I can tell, you surrender any and all control of your panels and battery to the VPP, because there's no way that anyone could write a sufficiently useful set of "rules" as to how much you would be willing to let out of your export meter at any given time. If one of your main interests is to have enough in your battery every evening to get you through the night without having to import, you could easily find yourself with nothing in your battery at the end of the day, or part way through the night, and then be paying import pricing instead of paying nothing. I cannot see how this cannot come to pass.
    • majority aftermarket is an10 yes, but majority of OEM is An12 r35 OEM cooler lines at close to an 12, the hard line that car uses is almost 20mm  Porsche OEM is also AN12   i figure, if our power levels are close to 1000hp, then AN12 should be a must if many OEM standard power vehicles use AN12
