Just get Braided lines and good fittings, thats what I did, as mine is low mount too. They aren't that hard to work on, just need to be smart on hose lengths and types of fittings.
I used those Blue and Red fittings - not sure on the brand. And they are fine because the turbo has been off 4 or 5 times now, being change to a bigger one, and changing rear housings etc.
Nissan used hard lines and banjos for a reason - reliability
keep in mind hard lines are alot cheaper then braided lines which is the main reason nissan weld with them
they also dont have as much flex as a braided line and they can also rust and leak
braided lines is alot more reliable then the standard hard lines
They also don't bake and crack when exposed to extreme temps. I have lines running in close proximity to my manifold, which is HPC coated as well as heat wrapped but I still expect to see some serious temperatures down there.
There is enough flex in the steel line to accomodate the sort of movement they will experience and I really don't think rust is an issue
Thats why you cover the braided lines in flame guard sleeving, to keep the heat away.
Just use Earls fittings (including their banjo bolts for oil and water on the block), and you'll have trouble free use. Just be sensible when routing the lines, ie; leave an air gap between the line and heat sources. Every drag/circut/rally racer cant be wrong about these fittings. Dont bother with hard lines; their lack of flex and/or vibration resistance would worry me.
Shaun.
id be steering clear of the orange stuff, it eventually go's hard and crumbles - also know of guys who have had it ignite. use the silver stuff around the manifold and if your really worried use teflon lined braid and as long as its roughly 1" from the manifold it should be fine
I used teflon/braided lines with my low-mount GT30 setup, never had a problem.
Just use a nice 90-degree speedflow fitting to lead the line out away from the housing/direct heat and it shouldn't have any issue.
The hard lines certainly are more reliable, teflon etc doesnt like extreme heat. Only issue with hard lines is if your pulling the gear on/off a lot that you dont accidentally bend them... thats where the problems start
Only issue with hard lines is if your pulling the gear on/off a lot that you don't accidentally bend them...
Tis why Id say banjo's are a good idea with hard pipe; the fitting itself doesn't travel during tightening... if that makes sense.
Depending on the type of teflon its good for around 350-500deg C. So i use braided/teflon oil supply and return line. I am with Shaun, i use the silicon sheathing for my return line as absolute overkill and never been a problem, even when thrashing the guts out of the car at the track, even after a fire :thumbsup:
Even after the fire the silicon sheathing only got a little scorched and coudl have been re-used, I got a new seciton as it looked bad, still worked fine and was ductile enough at the time of removal . The replacement went on in Jan 05 and its still there and happy
Hey Shaun, have you changed your turbo's water exit, and run it around the front of the motor, instead of the rear coolant line that goes around the back of the head?
Yep, i blocked the rear feed off, and returned the water at the front. You can see it in the photo; heaps better and not a nightmare to fix leaks etc. I dont know what i was thinking running it around the back.
Shaun.
Banjos are good for restricted spaces too.
Just make sure you replace the copper washers after re-use.
Actually, you dont have to replace them if you anneal them. Heat them up to red hot (using a torch or even BBQ flame), then cool them down by quenching or letting them self cool (it doesnt matter). This re softens the copper and theyre as good as new!
Shaun.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1.Anna S 2. Luke S 3. Jesse Givens-Lamb 4. Luca Stamatescu 5. Madeleine Stamatescu
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
