My motor had an oil return from the back of the head but when we put it in my car it didn't fit (was in a commodore) so we put a blank there (the fitting for the return was so huge it was preventing us from tilting the motor back to get the gearbox in and out).
Now this hasn't presented an issue until a track day a few weeks ago where the sustained high revs started pushing a heap of oil into the catch can.
I'm trying to find the slimmest possible way of putting a decent sized oil return back on.. something along the lines of drilling/tapping the blank fitting in there at the moment and screwing in a banjo fitting of some sorts..
Any suggestions? and how big (ID) would the return have to be?
The problem is it's a gravity return, no pressure to move the oil though the pipe/hose. Plus, at high rpm, there is a lot of oil to move. So the biggest possible fitting and hose is the go.
Cheers
Gary
Thanks Gary :(
Yeah I figured it was gravity return and that's why the old fitting was so large.. wonder if I can find/make something that is wide but not deep..
Maybe two small banjo fittings.. guess I'm going to have to peruse mucho catalogues and see if there is anything to suit.
If I drill/tap the existing bung I have in there, I would need to be doing so as low as possible yes?
Yeah that's pretty much what it used to have but that fitting sticks a good couple of inches out the back of the head, there is probably *just* enough room to have it there but it has to be taken out everytime the engine goes in or out.
I'm trying to come up with a way to do the same thing but with something that only protudes say 20mm out of the head.
Edited by bubba
I machined up and fabricated one that fits the ID of the whole welsh plug hole with an ally pipe coming off it that goes down towards the inlet side, the ID of the return pipe is 3/4" and has a -12 fitting on the end. The whole block sticks out 39mm from the back of the head. In our r33, there is no problem with clearance when taking the motor in and out. The same fitting was used in a r32 4 door and the firewall had to be moved back for it to clear, but it wasnt much.
But both these are used in dry sump setups. But I would imagine you would want the return as big as possible as gary stated.
As said you can always move the firewall back a little!
just tap it in, give it the old tap tap taparoo.
Whats the problem you oil fitting you to good for your home???
ok im tired, im going to bed now...
lol wut?
get some sleep and try again :P
lol, don't worry, I got it, Happy Gilmore ftw!
I've got the same fitting as Al, also with 3/4" return and I don't have too much oil in the head problems. Mine is tapped into the head beside the welshplug though because a the engine doesnt sit flat in the engine bay and b you cant tap into a brass welsh plug so you have to machine a replacement for that as well. this is in a 32 (gtr). I have massaged the firewall for tilting clearance but did not need to just to fit it :thumbsup:
Cheers guys.
My head has had the welsh plug removed and thread tapped in, there is currently 1" BSP plug/bung/blank/whatever in there. Been talking to my mechanic and we're just going to put the old 90deg fitting that he was using back in.
Any dramas with T'ing into the turbo oil return?
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG is has not responded to my emails so far after purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
