GRW Racing guys are hardcore... we smoke a compacted mix of ice, tobacco, pot, crack with no filter. Once rolled we dip it in acid and add a fire cracker to the end for a easy start
wow that would hit you as hard as this guy
  • Replies 461
Posted Images
Twisty your Mum isn't invited... So we won't be seeing a cheap hooker at the track....
Scotty,
Once again your creative writing classes are starting to pay off......
But I have something for you....
Take a Memo,
Your Fucking Fired!
Team RamRod's Motto
If You Ain't First, Your Last ( I'm Looking at you TGWPR!!!!)
Scotty,
But I am something for you....
Take a Memo,
Your Fucking Fired!
Team RamRod's Motto
If You Ain't First, Your Last ( I'm Looking at you TGWP!!!)
Sounds like loser talk from a loser... LOSER!
Team RamRod's Motto
Team Green Wang Pump's Motto
"Here we cum, there we blow"
watch out guys cos GWPR is pumped up and ready to race... correction masacre the challengers
Just another da at the office as the whipping boys
to Team RamRod's success......
Scotty,
do you guys want a large dose of reality?
or just the usual dose of humiliation to be handed out
we will give you that choice.
Who says Team RamRod isn't thoughtful?
Scotty,
you guys are thoughtfull... you thought you would win
Man, I can't wait to see the result of tonights racing, where Mike get's humiliated in front of everyone, I think we'll make him present the winners trophy to Nigel and I :D
Man... why do I choose to associate myself with such delusional people? The trophy WILL be presented to GWPR and i would suggest some kind of fireworks & jet plane flyby to comemorate the event.
Boys take your Meds....
We cannot have you circulating out on the track with dellusions of
success. You will only slow yourselves down.
For anyone coming tonight, for a tour of the pits
speak to Makka and Scotty. They know the layout intimately......
How laps did you clowns actually do last event?
We did enough to know that we kick ass. rather than lap everyone time and time again... we figured it would be best to pull in to the pits and give everyone else a turn.
Maka and I may spend some time in the pits today, I would suggest that anyone not driving come and see us for some pointers!
Pointers in watching a decent race,
pointers in the art of failure
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
