Looks great James. I would also love to put my hand up for you to come over one arvo, have a few beers and chuck 2 of your wheels on the V35 just to see how they fit/look. I have been thinking about XD9s for ages.
Yeah no worries Andrew, should fit nicely on the 35, 18x10 +15!
Got to get a few thing looked at (leaking hose under manifold, pin hole in oil cooler) but should have those sorted this week hopefully.
Yeah Jarrad but they were the wrong colour, and the fronts were too weak offset. I take it you sold them in the end?
And James, that is the exact size and offset I am hoping will sit flush but not rub, so am keen to try some that size out. Will catch up when you are good and ready - no hurry.
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
