New favourite; looks...quite different. And before anyone says shit about fitment i already have new rims n tyres. 18x9.5 +38 gunmetal CR Kais, just trying to get the fronts to fit atm :D
back with stock rims on atm but even so, still my fav so far :)
This one - (my fav pic of the car)
GTR hunting in its natural environment
I can just hear David Attenborough commentating to that picture
"And you can see the gtr here, frolicking amongst its prey. Its only a matter of time until it unleashes its power"
New favourite; looks...quite different. And before anyone says shit about fitment i already have new rims n tyres. 18x9.5 +38 gunmetal CR Kais, just trying to get the fronts to fit atm :ermm:
Thats quite a transformation!
Looks awesome.
You should think about painting your mirrors black too though.
    • How many of you guys run the synchro os giken set and at what power? Do you then also use the billet plate?  How is it launching with it, any dragy times from 0-60? 60ft?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
