Looks killer Stewy! Looking forward to seeing you do well at Matsuri also!
Nice ride there Jake! Welcome to the SAU:SA Club! Did you see our display last week at the Kadina Show'n'Shine? We had 10 or so very nice Skylines there.
hahaha thanks mate!! nah i was in adelaide that weekend lol i knew nothing of that show and shine .
let me know when ya all up this way next. go for cruise/drinks/food ect.
It's hard to say an actual price, i got an absolute deal on it though, i spent a fair bit of misc costs on it, but under 7k.
Fair enough man.
Did you end up emailing the old owner pictures of it all bent and and cut up in the container? lolol
Fair enough man.
lol i really need to get his email off streeter. the only issue is i dont wanna get streeter in trouble, as he was the go between for me and him.
3500kg tow capacity - great for towing race cars!
And spending more time getting fixed then driving! mates uncle has one of them, reckons its nothing but trouble... Maybe he just got a dodgy one haha. Nice car but.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
