na some bloke on my fb lol
luke took this one......a bit later in the day when tyres jumped out in front of me :P
not the exhaust pointing the complete wrong way and sticky tape holding th paint on the rear quarter :laugh:
yeah pretty good dude, only things were temp issues and a split coolant line, was only a slow leak so a top up after each session got me through the day. We are pretty sure the temp issues are linked to the split hose and cooling system not being able to pressure up properly, see how it goes at G1 i guess.
pretty happy with these shots from the weekend! had to pay for the hi res copies, but worth it.
Looks very tough in this shot, nice. Much damage besides the obvious? Saw the vid, looked like fun.
This is probably my favourite front shot of my Ceffy at the moment, took it about a year ago, made it onto Speedhunters. :)http://speedhunters.com/archive/2010/08/10/readers-rides-gt-gt-your-classics-pt-2.aspx Currently getting a FMIC installed and the bonnet will be resprayed to match the rest of the car in the next couple of weeks, so it will be looking a bit different soon.
And I kinda like this recent one of the rear a couple of weeks ago, just a quick snap parked outside a friend's house.
Edited by Stang
not yet, only put em in tonight. theyre made by Qest.
if people are interested in a set, they make em for 32s and 34s as well as all 4 doors variants and also for FD RX7s and JZA80 supras and the bloke who brought mine in is organising some more sets in the very near future. they also make different styles, and you can even choose the colour of the boards too so theres about 20 different variants just for a series 3 gtr like mine!
look out for the thread about them soon
their the one i sent joo ages ago menzell. there supposed to be the shit, and judging by the photos the best LED ones out there, (apart from nismo on a 34)
im still undecided on the led indicators and reverse light/fog light though. would be keen to see a pic with them on too
Thought the name sounded familiar. They do look quite sexy
agreed. the other aftermarket variants of R33 LED tail lights look like 4 cleveland steamers on the back of a tugboat
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
