please swap them back...
Agree. That car does not suit the chromies. Much prefer the SSR's on it.
semi's on a dyno?? good way to chew em out >_<
From what I have heard from the master tuners, the older/harder the tyre the better for the dyno. Semi's will be getting chewed, not good for the dyno. A perfect example was a couple of years back, Matt's burgundy 33 was struggling on the dyno with the semi's. Changed the tyres to a street tyre and presto....much better on the dyno.
my wheels dont poke that much, and fitment is what jap cars run!?
unlike the +45 x7 wheels falcons and holdens run.
also sticking with the japanese theme (domokun) in the front window.
oh but you drive ford, excuse me for being so far from imports on a import forum.
but but but 20x7" chromies with +50 offset dumped on it's rears with standard front suspension pulls the bitches at maccas bro
sometimes I wonder why you frequent a skyline forum haha
ahaha
2004 BA xr6t, silhoette,leather,premo sound,elec sunroof,turbosmart bov,advanti 19s, rapid v3.0,k&n,dba slotted, centre muffler removed,tripod,siemans deka 60lb,valve springs,actuator,walbro pump,king spirng ssl/sl combo,whiteline 27mm swaybar, s.a race auto 2800 high stall,PWR trans cooler and my cat went missing.........327rwkw..........Bruce Heinrich Tuning
elec sunroof, turbosmart bov,advanti 19s, rapid v3.0,k&n,dba slotted, centre muffler removed
turbosmart bov, advanti 19s
advanti 19s
definitely in a place to be giving others shit about their wheels...
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
