My Girlfriends new toy
hey mate very nice. where did you pick it up from? is it all original
Got it from Perth Its pretty much original and the bits that arnt could have been dealer options.
Im trying to talk her into a set of Work Equip 03's or Rota RB"s.
and i want to move the mirrors off the door's and onto the gards but that will be a later job.
This makes me keen to abandon my 32 GTR project and get a 240z.
maybe i will just do both lol
it needs mini lites;)
seen a couple on jspec for high 20's
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
