  • Replies 40
Hi Rekin,
Yes AutoTechnique is their co-business and it does look they are a Holden/Ford shop but they have informed me that they are moving into the Japanese car market.
This is the first year we are using them for the Dyno. They have a pretty good set-up with Plasma and Sofas for the Dyno etc.
Even if you dont end up Dyno'ing your car, come down for a watch
cya
Bran
I think it will be great to come down.
I printed the flyer off today.
I'll probley come down and spectate, take some photos, get some BBQ and drinks ;)
The Dyno day at RE Customs was kick ass! Big turn out.
For sure everyone is welcome.
I am not sure how big of a turnout it will be this year as I seemed to of chosen a date just after a few Dyno Days have just finished :D
Sure man
I try and spread the word and get afew ppl down to spectate and dyno if not already done at the SAU Meet Dyno Day at RE Customs.
Sure man
Thanks buddy. Appreciate it!
I might come down and put the car on the rollers.
is there likely to be many big numbers cars there?
Well a few years back some of the GT-R guys came down like Snowy, Frank and Ferni they had some great numbers but this year Im not sure.
This year there is an BMW M5 coming, M3,
An Audi RS4 is still tentative.
A C63 AMG Merc is also Tentative.
If the Evo X is released before the 5th then there would be an Evo X coming.
This year there seems to be a lot of clashes with other things .. a lot the regulars are not coming :ninja:
So ... Hard to say guys but I hope so :P
wouldn't mind seeing how the power of my car is on another dyno with new plugs and cleaned throtal body
Its a good way to see how the car is running.
i always see monaro's parked outside the place, so im guessing they will also be attending hehe
Yah they probably won't be. But we are deciding on a car to be a Mystery Car for "Guess the Kws". Raffle
The WRX club sprint at Calder has now been canceled. Might pop down Brandon ;)
Yah if you are in the area pop down.
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
