Hi all,
Im trying to pick a tyre from the Federal range. I have two options:
Federal SS-595 255/40 R17 96W
* Low profile sidewalls for ultimate performance
* Excellent comfort characteristics
* Uni-directional tread patter
* Flange protector for alloy rims
* Affordable price
* ZR and VR speed rated
Federal 595 RS 235/40 ZR17 90W TW
New, semi-slick, sport competition 595RS - designed for exceptional traction and grip. Cutting-edge technological advances in design, construction, pattern and compounds. Best performance in its class - a street legal competition tire with the characteristics of a slick.
* Evenly dispersed block stiffness, same level of stiffness in the center and the shoulder for stronger grip and traction, prevents irregular wear
* Uni-directional V-shaped main groove enhances streamline form and also improves aquaplaning ability at high speeds. Wide-angled grooves increase block stiffness, further enhancing tire's grip and traction
* Engraved pattern name along the groove creates an exquisite product image
* Sub-grooves on the shoulder disperse block stiffness, improving ride comfort, grip and traction
* Complete block stiffness provides excellent lateral stability in cornering
Now the SS-595 is a high performance street tyre with a width of 255. While the 595RS is a semi slick but with a width of only 235.
Would the extra width of the SS be better than getting the RS?
They will be going on a set of 17x8.5 wheels for the track.
https://www.sau.com.au/forums/topic/224552-help-me-choose-a-federal-tyre/
take the RS if ur doing track
Im running 595 ss on my r33 gts t. only 6 or 7 months old... and they are shit for grip. especially in the wet.
Im running 235 at front and 255 at back, even with the extra width fails to hold under high load/revving/boost.
Cant imagine running SS on track... waste ur time and fuel.
Not sure on RS never used them b4, but i have heard good things.
Edited by br3ndan
just bought a full set of federal RS 235/45/17 for my r33 gtst. so far so good, traction isn't an issue with 280rwkw. taking it to the wakie track day this saturday, i'll let you know how they perform there shortly :ninja:
why does it have to be federals? there are plenty of other tyre options out there, and to be honest the federals haven't impressed me all that much, except that they are dirt cheap.
Cheap,yes they are. just wanted to get peoples opinions of them,especially the RS ones.
I've been using the R's for quite some time now and IMO they rok. No they are not capable of the same lap times as some of the more fancied semi's available but they are unpteen times more durable and are still streets ahead of any street tyre for grip.
I would rate them in between good street rubber and high end semi's for grip And with 16000 kays, several track days and other sheanigans on board mine are still going strong.
Definitely one of the better compromise tyres out there considering the cost versus performance versus durability.
The 235/45-17 rs cost almost as much as a 235/45-17 RE55. If you have a set of track only rims you will be a lot happier with the re55 (as in once you figure out how to drive around wakefield properly about 3 seconds a lap happier)
I have 225 RS's on the front of mine for street duty and the occasional wet track day where they are excellent but as soon as the dry line appears the re55's go on as they are that much grippier.
Another thing worth considering is the deeper tread depth of the street tyre, smaller tread blocks and softer sidewall don't feel very nice when you are really pushing and you tend to melt/feather the edges of the blocks a lot easier too. You will probably overheat the tyre so grip falls away further, it will happen sooner in the street tyre than the proper semi.
i wouldn't even consider the SS for anything other than street duties.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
