rule 1: Trex101 advice is a MILLION times more valid than mine.
mate, if you can get some GC 0w30, go nuts! afaik, step above the Mobil 1 0w40
this too thin stuff is crap. Trex101, khunjeng, REALLY know their stuff. It's 110% fine... don't worry about what your local mechanic says >_<
Have you tried Redline Light Weight Shock Proof? If have and doesn't work then Redline D4 ATF (only ATF rated GL-4) maybe what you need to squeeze out of whatever remaining life from your GB.
Cheers but I'm not going to waste $100 on oil when a whole gearbox will cost ~$500. Just curious if its worth it to prolong its life a bit more, if it won't help I wont bother. Anyone ever done this and had any results?
So how would I know if its protecting my engine enough? I mean it will prob cost $100 or so for it concidering its 5L I assume like most oils if I see it dropping in level quickly it means its being burnt off to quick and not protecting my engine?
Im really not into a rebuild .. I trust the advice im just taking procautions to avoid a catastrophie
Thanks
Thanks
Do a used oil analysis, khunjeng knows where to get it.
Is your engine having oil consumption? If yes, find the root cause first & fix it before you try new oil.
No its not .. its fine I just wanted to make sure the advice you gave me is able to be backed by a test .. concidering its fairly expensive wouldnt want to run shit oil and have to put more in later
mate we are no here to prove anything to you. If you dont like our advice then dont take it.
If your unsure buy Mobil 1 and be done with it.
Hows GC 0w-30 sound to you .. Trex101 said to grab some .. but im skeptical as the recommended is like 15w-40!?
yes get it and get it off Harold via his web site or ebay. His prices are not much more expensive than M1 off the shelf in Repco.
mate im just asking a question.. dont answer if you dont want to .. dont give me shit for asking tho
All I asked was would your advice cause premature wear on the engine and how could I test it .. What do you expect me to trust the advice of two randoms on a forum ive never met and all I know you could be 12?! common the questions are fair enough I just want enough infomation and ways to prevent damage that I can get..
Jebuz!!
And more to the point ill be buying the oil :kiss:
Edited by DECIM8
If the box is only going to cost you $500, then you should definately go down this path. But to answer your question, yes the Light Weight Shock Proof will prolong its life. In mine it relieved the notchiness and allowed me to quick shift. Probably the best $120 I've spent on the car results wise. I didn't think it would work, but it did. This was after a gb oil change which had fresh Motul put in. Red Line is expensive, but well worth it in my case.
S/h RB20DET box is worth $500 from the wreckers.
'Some' attempt to rip us off and slug $800-$900. Always shop around. :kiss:
I've never had issues with the castrol synthetic oil in my box. I believe its what Roy uses also; unsure if he's recently jumped camp or not.
Hi,
I'm pretty clueless about things such as oils but I've read through the thread and I'm still struggling with the concept of oil viscosity ratings and which oil to use.
I've been having a look at : http://performancelub.com
And the price between royal purple and mobil 1 seems pretty close but Redline is damn expensive.
Anyway, lets use Royal purple as an example, they make:
5w20, 5w30, 10w30, 10w40, 15w40 & 20w50
Now, if I am reading correctly, the first number "5" means that the oil flows easier at cooler temperatures.
So the "10w" would take a little longer to warm up and start flowing easily?
And the "20w" would take even longer?
The upper number, "30", "40" et cetera is the temperature the oil thickens at when its hot, I can't remember how to work out the temperature but I know the larger the number the higher temp it will take to make the oil thicken is that correct?
I've been reading: http://www.autoeducation.com/autoshop101/oil-change.htm
Anyway, on my other question, I now own an R33 GTR with a fair number of mods (I'm going to find out exactly what soon) I know its aftermarket intercooler, radiator, full engine rebuild (unknown mods), and possibly aftermarket turbo's (the auction did not detail this). The car has also done 148K, Km
Would I be better off buying a Royal purple 10w30, or a 10w40? Or do I need to find out my oil temps during use?
Or would you recommend the Mobil 1 0w40 (or 10w30)?
The car will be street driven with occasional track use, but not anytime soon so for now it will be a street car :kiss:
Regards,
Gareth
The car will be street driven with occasional track use, but not anytime soon so for now it will be a street car :P
Regards,
Gareth
There is alot of factors to consider when choosing oil weight and it's quite difficult to give you any good advice by your above description.
There are 2 major considerations in choosing oil viscosity,
1) Fuel dilution (fuel blowby into oil sump effectively thin down the oil viscosity)
Thicker oil can withstand more fuel dilution then thinner oil but thicker oil also causes friction drag, slower spool, higher FC and more startup wear.
For example: If you run Penrite Sin 25 25w60 in your engine, at 10’c morning when you first crank your engine, you would have effectively run 1131cSt startup viscosity. That’s like 4.5 time thicker then Mobil 1 0w40 (248.8cSt@10’c). It’s like running greases through your engine instead of oil.
2) Engine oil temp
Higher oil temp effectively thins the oil down.
For example: Mobil 1 0w40 is 14.3cSt @ 100'c but when avg oil temp raise to 120'c, it would have thin down to 9.1cSt which mean that it is effectively a 20wt oil (you do not want to run a 20wt oil when you racing down a track, do you). So if your avg oil temp are 90’c, any 30wt oil will do as it is effectively a 40wt oil at that temperature.
The key to the correct oil viscosity depends on mostly the above 2 conditions. There is no one size fit all oil.
Oh, IMO some brand of oil are known to withstand quite abit of fuel dilution before thinning down. Redline & German Castrol is one of them. That’s why it’s highly recommended in BITOG for track or high hp muscle car usage.
Edited by Trex101
Hey got the oil prob out of the way. To get rid of the sticky lifters which i believe is cause the lifter noise upon start up im thinking of using wynns oil flush. Ive heard some conflicting stories about these products what does the skyline faithful think about them. Im sure it would help the prob but is it safe???
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
