The key to the correct oil viscosity depends on mostly the above 2 conditions. There is no one size fit all oil.
Trex101, thanks for your help, I'm still learning about things such as oil so I didn't know what you needed to understand about the car for a response.
Your post makes sense, I'll have a look around and I might try out Mobil 1 first as it seems to have quite a good reputation.
Although another question, if Mobil Delvac 1 and the normal Mobil 1 0w40 were the same price, which one would you recommend for a GTR?
Regards,
Gareth
Regards,
Gareth
If you can find Delvac that would be good.
There is nothing wrong with M1.
Regards,
Gareth
That's a hard choice. First, I would choose the cheaper of the 2, but if both are the same price, personally i would choose M1 0w40.
Delvac 1 though very well build couple with good base stock & additives pack, it still a dual rate oil (petrol/diesel API SL/CI-4+), this limits the friction modifier in the oil thus may affect FC and throttle responses. That’s why I’m slightly biases against D1 but it is still my first choice for 4-stroke bike though.
Hey guys,
Ive heard alot about these Penrite SIN oils, theyre meant to perform very well and im thinking of trying it next oil change..
Anyone running these oils? What would be be recommended for a r34 gtt around 60 thoukms' ... they have 15W-40 and 0w-50 in the brand?
thnx
Hey guys,
thnx
eeeeeee....... Pentrite sin and rb's should never be used in the same sentance.
Edited by URAS
i just put royal purple 10w40 in on the weekend, can't say i've noticed much difference (but i also upped the boost a little bit at the same time...)
but i rest easier knowing its got good blood in it.
**Also, anyone who is on the gold coast - tell autobarn to start keeping this on hand, cos I had to pay 8 freight when i had them order it in for me (sleazey c*nts) and then they say "hmm haha, we should keep this on stock, you're like the 10th person to order it haha" that's when i jumped the counter and smashed his head into the til, grabbed the cash, my oil (of course) and a little smelly pine tree for the road and then peeled the hell outa there! Or that's how i remember it anyway....
actually maybe we should ask them to stock redline while we're at it?
guys i think youve mistaken penrite mineral oils.... theyre pretty average i know... but check out thier SIN (synthetic) oils, rated very highly in recent testing.
Have a read of street commodores mag no. 108, they have tested the 18 top oils on the market through various tests. Out of them Royal Purple and Penrite SIN oils performed the best... funny to see the Mobil 1, Motul, Redline, and Castrol Performance synthetic oils performing so bad...
So just before you guys bag the penrite have a read its very interesting :D
The StreetCommodores editor has admitted that the test is flawed & not representative of actual engine condition in one of their articles. Street Commodores did indeed print a retraction and apology to its readers.
This simple Timken test is only good for grease then actual oil performance.
http://www.streetforce.com.au/news/01_oils_aint_oils.php
Edited by Trex101
Ah right, woops i didnt know that lol. Well then id still like to know someone who uses PENRITE SIN OILS! 15-40 theyre roughly ~$66 Castrol Edge 10-30 ~$45
Im kinda stuck with which to go with? Like would the benefits be that noticable? OR is thier anything else in this price range 66 is getting a bit high for me....
I've got Penrite SIN in my beast, the 15w
i used to run HPR30 in my RB30, its made for it, and they love it, so i thaught this was a fair compromise for my rebuilt 25/30 and the car seems to love it, i fully flushed my old oil (with a little bit of kero, then run clean from cheap oil, and left to drip dry for an hour or so) it seems to love this oil, smoothest its ever been (tried a fair few oils, though never royal purple or Mobil 1) way more rev happy, really smoothed out the poor rb30 bottom's top end revs (5.5-6k+)
and it seems to love a tassie cold start, no more noisy lumping, quiet and smooth, but then i have had no decent synthetics to compare against
go for royal purple.
what? its shit..... dont tell me you read the street commodores oil test........ what a sham that was. using a grease tester to test oils.... hello.
Mobil 1
Motul 300v
or Redline 10w-40 are the only oils i will use, after 12 years playing with imports i can tell you i will never ever use castrol (any, as there shelf oils are not what goes in race cars) pentrite sin (turns to water to quickly when pushed hard) or royal purple as it is just like every other plain jane oil.
Edited by URAS
Dont' rule out the German Castrol Trent :D (not available here, so you're still correct to an extent :P)
probably rubbish, i'm running 0w40 in my R34. Unless you're doing some SERIOUS track work, pressue will be fine
Hows the oil pressure on the mobil 1 5w50?? Ive been told with mobil the oil pressure can be a lil low when can gets hot?? or is this just rubbish!!!!!
Pressure is directly proportion to viscosity, the thicker it is the higher is the pressure. This also mean higher pressure will have lower flow rate. You need both flow rate and pressure to fully optimize the operation of the oil system. IMO 50wt oil is just too thick for most application except racing or autocross....
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
