Pressure is directly proportion to viscosity, the thicker it is the higher is the pressure. This also mean higher pressure will have lower flow rate. You need both flow rate and pressure to fully optimize the operation of the oil system. IMO 50wt oil is just too thick for most application except racing or autocross....
Rather than start an argument I would rather pose a question.
First things first what you have said is partly correct. A higher viscosity fluid will create a larger pressure difference when measured from one end of the pipe it is being pumped in to the other. This means a higher output pressure at the pump is required to achieve the same flow rate.
BUT
There is more than one type of pump. For a centrifugal pump (like your water pump) the output pressure has a huge effect on the flow rate of the pump. For a positive displacement pump it has ABSOLUTELY no effect.
So what type of pump is your oil pump?
BUT
It does when the bypass is wide open; in essence the thicker oil creating high pressure also causes a huge effect on the flow rate of the pump as it has to dump a lot more oil to hold its specified oil pressure.
With a 5w40 I see ~90-95psi of oil pressure over 3500rpm.
Nah i'll never take the odometer reading as gospel hehe. I just want to know if its a safe things to use. Ive been going through this thread and man ive got a headache and I just want to know what oil to buy tonight when i go down to supercheap. I just want something good quality and something quietens down my lifters abit during start up thats it. any suggestions for my 1996 R33?? Im sure its not rocket science but after reading a few pages im like damnnn oil choice is a massive decision.
yeah, you've asked quite a few times :(
I've answered with Mobil 1 a few times as well :P
0w40 in my car, took a little less than 5 litres i think. As i've said before, RB lifters are fairly noisy anyway, but the Mobil 1 did quiet them down a little, for me. NEO R34, don't know if that makes a difference.
i can't say anymore than what i've already said. I've got 0w40 in my car, and yes it made the lifter less noisy.
can't answer your question any more straight forward than that. And if people like Trex101 are telling you it's fine, that it's 100% cool. They're the sorts of people in this thread that i made my oil choices from. Trex101 and khunjeng, etc...
that's cool :(
mate, i was exactly the same, worrying about which oil to put, concerned about this and that. But some of guys in this thread REALLY know their oils. Mobil 1 is a good starting point, at a reasonable price and having 0w40 is fine. Then you can go German Castrol, Redline, Motul after that if you're keen.
i know exactly what it's like to be paranoid bout the car, especially with the oils. I also did my gearbox and diff at the same time, so i was 3 times as paranoid! haha
Maybe just PM Trex101 or khunjeng with your EXACT concerns and worries, and grab their opinion :P
nope, will still be cheaper i'm pretty sure :rofl: Even melb people have to pay for postage. The difference isn't that great between posting here or interstate.
ah okay yeh ive found those rates they aint that bad...
Pretty keen on the royal purple stuff for that price, anyone using this in theyre cars?
Guys,
Was just enquiring about gearbox oils at the Outlaw Speed Shop here in Adelaide, and got to talking about engine oils too. I was passed on this article to read/keep and had to share with everyone as it has some REAL eye openers.
I will more than likely be using the Royal Purple next, far and above the others for value for money I reckon. Almost makes me want to dump the Motul 8100 excess in there now!. However got to say that the Valvoline shocked me!
Cheers
Lee
Oil_Compar.pdf
Well I didnt get a price from Outlaw, but the listed price in the comparo is $79.99 compared to $92.99 for the Motul 8100 Excess, which you can get for cheaper than that.
By value for money, i meant for similar dollars to Motul, get far better protection for a full synthetic.
For a Semi synthetic, seems the Valvoline durablend is the go.
Its all in the PDF I attached to my post ;)
Edited by Hotwire
Guys,
Cheers
Lee
This article from StreetCommodore is very misleading, this Timken test are only good for grease, not oil. The editor has admitted the test is flawed and not representatives of actual engine condition.
StreetCommodore reply:
http://www.streetforce.com.au/news/01_oils_aint_oils.php
Wow,
Thanks for pointing that out. So the verdict is still out then LOL
You know, i can get better wear reading with head and shoulder shampoo then all these oil tested. The chorine in there are a very good extreme pressure additives, it just that when you include it in your engine oil combine with moisture, you will form hydrochloride acid.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
