Pressure is directly proportion to viscosity, the thicker it is the higher is the pressure. This also mean higher pressure will have lower flow rate. You need both flow rate and pressure to fully optimize the operation of the oil system. IMO 50wt oil is just too thick for most application except racing or autocross....
Rather than start an argument I would rather pose a question.
First things first what you have said is partly correct. A higher viscosity fluid will create a larger pressure difference when measured from one end of the pipe it is being pumped in to the other. This means a higher output pressure at the pump is required to achieve the same flow rate.
BUT
There is more than one type of pump. For a centrifugal pump (like your water pump) the output pressure has a huge effect on the flow rate of the pump. For a positive displacement pump it has ABSOLUTELY no effect.
So what type of pump is your oil pump?
BUT
It does when the bypass is wide open; in essence the thicker oil creating high pressure also causes a huge effect on the flow rate of the pump as it has to dump a lot more oil to hold its specified oil pressure.
With a 5w40 I see ~90-95psi of oil pressure over 3500rpm.
Nah i'll never take the odometer reading as gospel hehe. I just want to know if its a safe things to use. Ive been going through this thread and man ive got a headache and I just want to know what oil to buy tonight when i go down to supercheap. I just want something good quality and something quietens down my lifters abit during start up thats it. any suggestions for my 1996 R33?? Im sure its not rocket science but after reading a few pages im like damnnn oil choice is a massive decision.
yeah, you've asked quite a few times :(
I've answered with Mobil 1 a few times as well :P
0w40 in my car, took a little less than 5 litres i think. As i've said before, RB lifters are fairly noisy anyway, but the Mobil 1 did quiet them down a little, for me. NEO R34, don't know if that makes a difference.
i can't say anymore than what i've already said. I've got 0w40 in my car, and yes it made the lifter less noisy.
can't answer your question any more straight forward than that. And if people like Trex101 are telling you it's fine, that it's 100% cool. They're the sorts of people in this thread that i made my oil choices from. Trex101 and khunjeng, etc...
that's cool :(
mate, i was exactly the same, worrying about which oil to put, concerned about this and that. But some of guys in this thread REALLY know their oils. Mobil 1 is a good starting point, at a reasonable price and having 0w40 is fine. Then you can go German Castrol, Redline, Motul after that if you're keen.
i know exactly what it's like to be paranoid bout the car, especially with the oils. I also did my gearbox and diff at the same time, so i was 3 times as paranoid! haha
Maybe just PM Trex101 or khunjeng with your EXACT concerns and worries, and grab their opinion :P
nope, will still be cheaper i'm pretty sure :rofl: Even melb people have to pay for postage. The difference isn't that great between posting here or interstate.
ah okay yeh ive found those rates they aint that bad...
Pretty keen on the royal purple stuff for that price, anyone using this in theyre cars?
Guys,
Was just enquiring about gearbox oils at the Outlaw Speed Shop here in Adelaide, and got to talking about engine oils too. I was passed on this article to read/keep and had to share with everyone as it has some REAL eye openers.
I will more than likely be using the Royal Purple next, far and above the others for value for money I reckon. Almost makes me want to dump the Motul 8100 excess in there now!. However got to say that the Valvoline shocked me!
Cheers
Lee
Oil_Compar.pdf
Well I didnt get a price from Outlaw, but the listed price in the comparo is $79.99 compared to $92.99 for the Motul 8100 Excess, which you can get for cheaper than that.
By value for money, i meant for similar dollars to Motul, get far better protection for a full synthetic.
For a Semi synthetic, seems the Valvoline durablend is the go.
Its all in the PDF I attached to my post ;)
Edited by Hotwire
Guys,
Cheers
Lee
This article from StreetCommodore is very misleading, this Timken test are only good for grease, not oil. The editor has admitted the test is flawed and not representatives of actual engine condition.
StreetCommodore reply:
http://www.streetforce.com.au/news/01_oils_aint_oils.php
Wow,
Thanks for pointing that out. So the verdict is still out then LOL
You know, i can get better wear reading with head and shoulder shampoo then all these oil tested. The chorine in there are a very good extreme pressure additives, it just that when you include it in your engine oil combine with moisture, you will form hydrochloride acid.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
