performancelub.com... when i search it on google comes up with 'this site may harm your computer' under the name.. and is listed on google as having software that can harm your computer haha.. can anyone shed some light?
Due to the price of it I've always wondered if the turbolight semi-synthetic is similiar to that of the grpIII synthetics (castrol etc) that are not really synthetics. :thumbsup:
Could be......
I did a scan with my anti-virus and come up with nothing, it's safe going into this site. no problem.
oh, you could email Harold at [email protected] if you have any enquiry, he quite a helpful chap who will try to answer your questions.
Guys, sorry if this has been covered (not going thru 11ty billion pages), I just wanted to get an idea of what people think of Castrol Edge 10w-60?
For a 1990 R32 GTR with ~120k on the dial.
Been recommended to me by a reputable workshop, they use it on heaps of their cars.
Cheers!
Dan :rant:
Just spoke to Fuel Direct where i got my last lot of Delvac 1, price has gone up from $180 for 3x5L to $230+ delivery.
Also called Motorex in SA (saw that others have ordered from there) and they said they dont sell Mobil anymore, only Valvoline.
Looks like cheapest group IV oil is now Motul 8100 assuming you can still get it for $59. I think ill go have look for that this weekend.
Does anyone know where to get Delvac for around $60/5L anymore? Any good deals in Sydney right now?
Cheers!
Dan :P
Anyone?
maybe we should just do a poll....or something like that.
10w-60 seems like too wide a spread. most recommendations are aound 10w-40, 15w-40 or even 5w-30.
put it this way, how important is the health of your engine? if you don't push your engine all that hard, you should be pretty right with regular run of the mill oils.
however most people agree that fully synthetics are the way to go for hi-power engines that are 'opened up' on a regular basis.
motul chrono and redline are two oils that seem to be trusted by almost everyone, however they're expensive, soooo to answer your question (sorry i work for the govt so i like to run around in circles confusing people before i actually get to the point and even then it probably doesn't actually answer your question but by then you're over it and just nod and say ok and leave) i think i've seen fairly low opinions of castrol edge on this thread. although i THINK (don't quote me) sydney kid uses castrol products on his track car.
or you might want to type the word castrol down in the left corner there
Edited by made_guy
How about Mobil 1 fully synthetic 5w30 oil? would that be better then the Redline 10w40 oil? i pay about 82 dollars for 5 litres of the mobil one, my engine has done around 60 000kms ish so yeah which is the better oil to use?
sorry if it has been covered
Cheers
Chi
Cheers
Chi
Redline is better cos its ester based group 5 oil. Mobile 1 is synthetic too but belongs to group IV as it does not have ester.
Mind you I might try Mobile 1 myself at the next service... i just cant convince to spend over 200 bucks for an oil change when my car does not see the track and is stock.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
