Redline is better cos its ester based group 5 oil. Mobile 1 is synthetic too but belongs to group IV as it does not have ester.
Mind you I might try Mobile 1 myself at the next service... i just cant convince to spend over 200 bucks for an oil change when my car does not see the track and is stock.
whooah! why you spending $200?? redline from performancelub should be around the $100 mark delivered for 5 quarts.
Hey thanks for that.
Redline Synthetic Oil 5w-40 from performanceclub.com is about 17 bucks per 950 ML. So thats 6 * 17 which is around 114 dollars. How much is the delivery charge from them as it does not say?
Cheers!
Cheers!
Why don't you just ask Harold from performancelub.com about the shipping charge?
^^yep yep he links to the aussie post calculator, but will give you a proper quote quick smart if you email him the order.
how come you're getting 6 quarts tho??? i doubt a skyline would need 6 to be honest. even with a filter change
Dont we need 5 litres of oil for the engine? So if you only buy 5 * 0.950 ML thats like 4.75 litres. Is that enough or do we need 5 litres exactly?
Also if the car is stock, sees no track and seldomly gets floored on the streets, can I just service it every 10,000 KMs?
hmmm today i went into Auto one and i also read the oil review that was attatched to this topic...mmm the guy was telling me that Penrite Synthetic "SIN" 5 5w60 is way better then the Mobil 1 Fully Synthetic 5w30? and also the oil review also had better results from the Penrite...im talking about the one that was using the bearings and showing the marks etc etc....so the question is keep using MOBIL 1 or try Penrite? any help would be sweet :D
Cheers
Chi
hmmm today i went into Auto one and i also read the oil review that was attatched to this topic...mmm the guy was telling me that Penrite Synthetic "SIN" 5 5w60 is way better then the Mobil 1 Fully Synthetic 5w30? and also the oil review also had better results from the Penrite...im talking about the one that was using the bearings and showing the marks etc etc....so the question is keep using MOBIL 1 or try Penrite? any help would be sweet :laugh:
Cheers
Chi
dont care which gay test results some shows you, M1 is better oil. Get it and you will be happy.
which one tho? the M1 5w30 or the 0w40? :D
Cheers
Chi
depends on how you feel. Generally people have been going with the 0W40. In asutarlia we are scared of "thin" oils. If its for street use, thin is great to reduce startup wear. However if ur gonna see some track 40-50 weight be better. Generally for a mixture of booting it around racing excels and honda accords, 0W40 would be fine (M1 of course...)
hey everyone, read about 90% of this thread, but still having troubles gettin my head around oils and fluids, so i was wondering if anyone can help me out as im going down to autobarn later today to get evrything, i drive an rb20det r32 1993 done just 120,000 clicks, i use the car the putt around in but i do give it some every now and then and plans for hitting the track in the future as well,
so far im swinging towards this
Diff - Motul Gear300 75w-90w
Gearbox - Motul Gear300 75w-90w
Engine - Motul Xcess8100 5w-40w
Coolant - Castrol Anti Freeze
Brake Fluid - HAVE NO IDEA...HELP
Power Steering - HAVE NO IDEA EITHER
i think thats all the fluids/oils i need but if ive missed one could sum1 please point it out, be much appreciated!!!
and also could people tell me the amount i need eg. 2 litres for diff
thanks
Edited by mic_check_1_2
Gearbox - Motul Gear300 75w-90w (Redline lightweight shockproof)
Brake Fluid - Any Dot 4 or Dot 5.1 brake fluid
Power Steering - Any Dexron III spec ATF fluid will do
Edited by Trex101
I havnt been happy with shockproof and went for MT-90 instead and been quite happy with its shifting ever since!
    • Resizing injectors in Nistune can be done a couple of ways, and there are a couple of ways that you can make a mess of it. The tuner needs to be really aware of the effects of whichever approach he uses (either K, or TIM). They are both easy enough to "get the injector size right" to run the engine. But little details like old start enrichment and hot start are affected differently, depending on which boxes you check.
    • Pretty safe to say almost everyone that has tuned their own car has experienced this issue. The difference being that we have our laptop in the car and when it happens, it's literally 10 seconds of tuning to sort it.  Would you be happy to plug in your laptop and sort this yourself? It is a very simple process and there is no risk of harming your engine (if you are worried about that).
    • Yeah thats the next step now, either they wil or i will take out for a drive to work and go straight their after work and see is we get the same issues 🤞  thought i try my luck here too, never know someone else might have had the same issue but thanks for the reply
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
