Your oil getting black is from the detergants 'cleaning' your engine, you certainly wouldn't want to be getting black oil just from blow by.
If you change oil only every 5,000km's it should be slightly black, by 10,000km's if it aint black I would be worried, either the engine is impossible clean or the oil aint cleaning sh*t.
I think Mobil 1 would contain aleast an average amount of detergents, it recommends on the back of the bottle for GTR's i think,
Actually the oil I drained out was exactly 5litres. And its the first time I've changed the oil since it came from japland
Checked the dipstick and it seems to be fine
who says to use 3.4L? that would be on the low mark on the dipstick surely...
Personally i fill mine a bit over full , upto the H and thats 4.5L
Seems Chequered and Racepace are using Catrol Edge 10W60 for track work. I've got an oil change coming up and my car does mostly occassional street driving but will see the track from time to time. What's the latest thinking? Performance Lube are suggesting 10W40 Royal Purple, citing with group 4/5 synth oils 10W60 is thicker than it needs to be. I'm running a 310RWKW RB26 with extended sump and oil cooler.
Where is recommended to buy the Catrol Edge 10W60 if it ends up being the go.
Keep it simple for me guys.
Thanks.
RP 10w40 would be my oil of choice after the Edge (which is easily bought from most parts places and cheaper).
It's hard to judge without UOA's or filtergrams tbh, though I did see a car on another forum where they changed from Edge 10w60 to Penrite 5w50 and ended up with a lifter dragging on the cam and scoring a lobe. That was on an aftermarket cam with a fairly aggressive ramp rate though.
Mine goes in for a service tomorrow, so should have the sample off for testing within the next few days.
Thanks.
As recommended by Racepace iv been using Edge 10W60 for many years on my stock rb26 with 290rwkw without any issues, mainly street duties. Now same on my forged engine. They know their RB's!!
Buy it from repco or autobarn wherever is cheapest.
I would of thought using a light oil like 0-40 for street duties and a thick oil 10-60 for track would be sensible, and dropping the oil after each purpose is fulfilled, im guessing racepace wouldnt build the tightest engines if there built to be thrashed around a track, originally the 0-30w recommendation must of been for a tight motor out the factory.
My motor was stock on my last gtr and still ran the same oil as many other gtr's without any issues. My friend owns it now pushing same power 5 years later. Most gtr's are modified also which also has to be taken into account, factory recommendations go out the window. Besides these are engines designed in the 80's, not exactly modern tight engines.
Anyway I just listen and trust what they say, I'm not gonna second guess their knowledge.
Sounds like good advice there James.
Opinions are like arseholes, everyone has one. Try a few different grades and see/feel how your engine responds Flavzz.
Thicker oils will feel more lethargic until the temps get high but will offer more protection for the track. They will also take longer to drain back to the sump which is a common RB issue.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
