Pretty sure it was Jayce, Goran and yours truely in the GTR's.
Hey Richard, long time no see. how you been?
It sure was you, Jayce and Goran in the GT-R's (Jon, supafly, and chris in the gts-t's)
It was truly a spectacular entrance and my mates and dates had a ball on the trip out, definantly talked about for a while. Skyline convoy is always a good option :laugh: you would already have three organised :D
  • Replies 95
Posted Images
huh formals already??? damn that was quick, me better get the old girl out a bit, maybe a hose down, and a drive to stretch her legs...have neglected her for the best of 2 years...oh dats right, she still not ready.. just yet :(
i must be getting old, memory not to good can vaguely remember the cruise with jayce & young richard :)
Dont mean to ambush this thread but...
Snooze you .... (well you know the rest :D ) QUEENSLANDER's WooT
Goran think I'm in the same building as your Mistress...otherwise she has a twin. Now there's a thought!
Hope to see you on the road agin by Christmas :whistling:
Go right ahead and ambush all you like, thank goodness we're not as intolerant in the ACT section, its one of the things I like about ACT section (PS thank you Shell for not being a forum Nazi LOL)
Queensland need a thumpin'
Perhaps I could driver her in the "The Mighty Starlet" TM? Aye??? Bet you'd like that, huh, huh, huh?
Boom boom boom boom
I want you in my room
Lets spend the night together
From now until forever
Boom boom boom boom
I wanna go boom boom
Together in my room
coincidence?
Boom boom boom boom
Boom boom boom boom
Together in my room
coincidence?
You know whats really sad... that you know the lyrics to that song.
I thought we were all singing the song from 'the outhere brothers'
I say boom boom boom now let me hear you say wayoh (wayoh)!
I say boom boom boom muthaf***a say wayoh (wayoh)!
Girl your booty is so round
I just wanna lay you down
etc..
there really are a lot of songs with 'Boom Boom' in it.
Boom boom acka-lacka lacka boom
Boom boom acka-lacka boom boom
It was a night like this forty million years ago
I lit a cigarette, picked up a monkey skull to go
The sun was spitting fire, the sky was blue as ice
I felt a little tired, so I watched Miami Vice
And Walked the dinosaur, I walked the dinosaur
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
