got any pics of the yellow r33 with cf bonnet?
You've missed tonights edit, but I did get photos of your car (its memorable and sticks out).
So there's definately photos of your car. I'll see what I can do about posting a shot.
If you're interested in a cd, I can incorporate your shots.
-Andrew
  • Replies 135
Sounds about right.. Dave was doing low 1:11's in mine... only time he seem to catch you was when you spun out one session I think???
Yeah think so, just after the fishook :) But I caught up to Chris and Dave in one of the last sessions when they both decided to have an EPIC FAIL on turn 1..I nearly went with them :blink: Don't know why that happened...all coming in to the corner to hot :D
I am really hoping I cracked the 1:10's that's awesome in my car, wont know till the next supersprint
Excellent Pictures coming through Andrew cant wait to see my CD :( the suspense :woot:
HAHA Jay with his hectic sideways action :)
Hiya...
There's a very good chance that I'll have some nice shots of your car. But I'll need a description that singles your car out a little more. Eg: Number plates.
The cost is $20 for a cd with high resolution images. If you can give me some more details of your car, I'll see what I can do about posting a shot.
-Andrew
Hey Andrew. Plates are DAM 168 (black with gold lettering).
Still none of mine :(
Jess - lol yeah I came in too hot, understeered, backed off to save it but too late....Dave thought he'd follow my lines for some unknown reason hahaha
SSCC sept 17th wakie im there :)
Still none of mine :woot:
SSCC sept 17th wakie im there :D
I think EPIC FAIL is contageous :( It would be a good photo if it was all captured..Not sure if anyone was behind me either :)
OMG HI5!! Brake upgrade by then?? :blink:
-Andrew
yeah f*ck it, i'll grab a cd. incorporate away.
hmmm memorable ay? i'm thinking maybe you snapped me coming into pit lane with smoke coming out of the bonnet? lol
brake upgrade being done for superlap lol
This is the only other set of calipers like mine in existance (checked with ap racing in england)
Crazy cheap for what you get. Bigger than daves brakes and allow you to run V8Supercar discs which are available from PWR in Brisbane. Serious stopping power
http://www.skylinesaustralia.com/forums/Ap...rs-t225299.html
Bigger isn't always better :D But in your case yes they are better.... :(
Downside is your brake pads are sh!tloads dearer :D
Great shots Andrew!!!!! Now someone tell me how to make that series my sig!!!!!
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
