  • Replies 181
I've been watching the British GT which is the Vipers, Ferrari's, Aston Martins, Gallardo's, 911's ect instaed of the little 2L tourers. they throw the 1/2 million $ cars around just as much as the BTCC cars
here 1 soon to be ex ginetta G50 (post 12 shows whats about to happen)
Ouch!
Ahhh ok, I haven't seen their GT championship, only the Euro GT3 championship. Where do you watch it? Do they have DVD's available?
Cheers
Dane
I watched rnd8 of the british gt last night and it was actually quite an interesting mix of cars.
rnd8 was when the viper cam from 14th to 2nd yeah?
i mainly started watching for my financial interests in the series now i'm addicted :) (luckily not in that ginetta)
cover of UK magazine "Motorsport" May 2004. The cover read "Senna at Monaco: A story of inch-perfect precision and mile-wide obsession"
there is only one thing you should note in this pic, the difference between Senna's line and that of everyone else's
R.I.P Ayrton Senna
R.I.P Ayrton Senna
That little black mark on the white armco on the left, 2 ribs down, was him the lap before.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
