to work it out, go to any japanese auction website and find the price of the car if you were to buy it in japan; generally 3.8-5.0 million yen depending on spec.
pay agent fee 100,000 yen = bout 1000bux
shipping 150,000-250,000 yen
10% gst australian tax
10% import tax
new luxury car tax
compliance = bout 1500-2000
new tyres + service
stamp duty = 3ish% i think on car
registration
commission to importer
be careful with cos cars with accident history fetch lower prices and have lower auction grades therefore the importer may buy one at 2-3 and tell you it was a 4-4.5
Posts #2 & #7 are about right.
Take someone familiar with the GTRs along with you whilst you're looking at the plusses. Whereas your mate can be more objective and look out for you.
Check Auction papers. At the top right hand corner is the Grade No. ie. 2, 3, 4, 4.5, 5. The higher the number the better.
You look for rust etc whilst your mates check out everything else.
Be very wary about the cheaper price vehicle - and be suss about anything.
Other threads in SAU will tell you what to look out for...
All The Best. Cheers, T
Never ever rely on auction grades anymore. They were reliable in the past but these days you cannot simply judge a car by the grading system. I've been searching for a good accident free gtr in Japan for months. On 2 instances, both cars were graded 4 so I got my importer's broker to physically inspect the cars. Both cars had been in accidents. They werent major but nevertheless, I wanted a car with no hits. If you're going to buy from the auctions, make sure to have someone check the car for you before you commit to it.
I'd have to agree on that too..
Cheers
This is one of the major car-buying issues of course, but plenty of hits can be repaired and the car will be like new. It's only chassis and suspension damage that is really ugly IMO.
Point is, don't run in tears if the car's been knocked, when an inspection reveals the repairs are up to scratch and the chassis/susp. is OK.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
