What will an R32 GTR with 1017.3rwhp, weighing 3156lbs, with 198lb driver and a full tank of fuel, Castrol Edge 10-60W oil, trust sump extension, RE71 street tires on stock wheels with stock 250,000km gearbox, on a 18.5 degree day with +4m tailwind, run at 12.35pm @WSID on a Saturday, first time to the track? :(
There is plenty of info on the projected and actual times achievable...with good and not so good steerer's. Can we also ban the "how do I make XXX Kw with my RB25/6 GTS-T GT-R R32,3,4" Maybe it's time for an FAQ/Guide on the subject. Just saying :thumbsup:
i 3rd that :D
Interesting, I was expecting to get flamed for the idea lol.
The other idea I had was an approximation of power to times but there's too many variables...so maybe just a where to drag sticky :)
Yeh, ban them all...........bring back the im i a GTR want to be thread.....
There is plenty of info on the projected and actual times achievable...with good and not so good steerer's. Can we also ban the "how do I make XXX Kw with my RB25/6 GTS-T GT-R R32,3,4" Maybe it's time for an FAQ/Guide on the subject. Just saying :)
well found out 2night at wsid my 34 ran 11.6@123mph with 2.0 60ft so certainly got a bit more there . Running on 19inch volks and rubber band tyres makes getting off the line abit of a hit and miss affair .
Dude, beg/borrow/steal 4 x 32 GTR rims and some Mickey radials and there's a very low 11 in that car if not a high ten.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
