  • Replies 78
Im trying to get some stickers made for Chris's car atm.... there is several of us getting them :laugh:
Windscreen banners front and rear..... they are appropriate but that's all Im saying :)
Don't think they will be ready in time though :down:
Im trying to get some stickers made for Chris's car atm.... there is several of us getting them :)
Windscreen banners front and rear..... they are appropriate but that's all Im saying :D
Don't think they will be ready in time though :P
So thats the secret plan, huh Chris?
All this time throwing us off track with new turbo this, new diff that, and really your going all out on mass HP increases with stickers!
Cunning mate, very cunning.
i might now be in this. a mate is 90% chance of not being ready and offered me his entry. it's just a matter of getting the silvia or 32 track worthy and strapping on my cojones and getting amongst it. maybe I should do what all the "smart" guys are doing and get a pro to do the driving for me so I can devote all my time to running my mouth. so dundan? wanna be my pro driver?
I'm pretty keen, but one of my hates is rushing around last minute to get ready for a track day, so I'm not sure I'm up to putting myself through that this week!
basically the choice is between:
1100kg with this: post-3621-1214978901_thumb.jpg
or 1500kg with this: post-3621-1214978978_thumb.jpg
for the silvia I just need to:
rebuild 2 calipers
fluid flush
fix up the seat a little
fit the new greddy intercooler
take it easy as no oil cooler
for the R32 I need to:
get fluids changed (the whole lot)
get wheel alignment
chuck some pads in it
maybe whack on some different tyres
fit my seat in (easy)
fit my harness (easy)
tough call.
lol. GTR would be good. I'm really torn. I just thought about it more. the GTR has bone stock suspension. the silvia has coil-overs, 2 way, adjustable castor rods, rear upper arms and traction rods, pinapples, GTST lower arms, adjustbale strut tops and good brakes for it's weight.... the plot thickens.
either way it seems I'll get punished by the weevil! why bother turning up!! :laugh:
The Zed lost brakes on the weekend and I just got it sorted with a new MC,
looking forward to this big time, see if I can beat at least one home. :laugh:
But as Richard quite rightly noted, Chris will be hard to beat.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
    • It sounds like you want what the Toyota Landcruisers have for their roof racks. Wanna know what you end up with? Rust holes in the roof, and water everywhere...
    • Discovered today that if I select reverse first and take my foot off the brake, then select drive, the drive indicator light works and so does the tiptronic gear indicator.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Does anyone here have any ideas?   Cheers guys
