  • Replies 42
i was thinking of a getz myself.
i used to work at hyundai, they are a good car in general.
just keep your eye on your rear wheel cylenders as they tend to leak.
also some were prone to have a knock from the rear brake. they are very tempremental with handbrake adjustment.
https://www.sau.com.au/forums/topic/226384-hyundai-getz/#findComment-3985965
Barina is also $14990 drive away these days.
well if you're looking into things as gheyz as getz etc, might as well go the whole handbag.
Its not for me...Im saving up for a current shape corolla ascent :)
Barina is a Holden... I am sceptical as how long it will be till the crap starts falling off. Actually I dont want another Ford or Holden, period.
https://www.sau.com.au/forums/topic/226384-hyundai-getz/#findComment-3986251
Brand new ST Tiida is $19990 for Auto
2006 models are as cheap as $14K
Bought my wife an ST-L model brand new with 5 years warranty and on road etc for $22K - Auto
Not too shabby at all... I like the look of this one
http://www.carsales.com.au/used-cars/deale...de&__Nne=20
https://www.sau.com.au/forums/topic/226384-hyundai-getz/#findComment-3986268
The Getz is POS.
We have one as an emergency car, i drive it when i cant afford petrol for my r32 :laugh:
Full of cheap plastic, vibrates on idle, loves to understeer, automatic isnt responsive. It jumps to a lower gear for no reason and makes a lot of noise but still doesnt move anywhere.
Isnt even fuel efficient, manual says like 6lts/100km. Ours averages like 8~
Ours is the first model to come out, so it could be much better in the newer models.
However it does save me petrol money :D
https://www.sau.com.au/forums/topic/226384-hyundai-getz/#findComment-3987359
If you buy a manual 1.5L they are good. They did win Australias best small car 2 years in a row. I mean we all know its a little dodgy that awards system, but they have all the kit, engine, ac, abs, airbags etc. Good for a run about. But really its not worth it if your keeping the skyline. $15k is a lot of petrol.
https://www.sau.com.au/forums/topic/226384-hyundai-getz/#findComment-3987379
Getz is crap.. Honestly dont buy it .. Its cheap, seats are crap, and it seems to fall apart.
I do have an Accent which is very good, its a 97 and goes hard for a 1.6 litre it spins first and second so pretty ballsy. Olds have a Elantra too $20,000 new which is cheap as chips for a new car with electric everything and onroads + insurance. Its very comfortable.
Id prob go for the accent for a good reliable car. cheap to run, I fly around with it on empty for a good 3 days.. fill up when the light turns on.
https://www.sau.com.au/forums/topic/226384-hyundai-getz/#findComment-3987401
I passed my driving test in a Getz (driving instructor's car, since my old VN probably won't pass the safety check.)
As a car to get from point A to B & back to A, it does the job, anything else... don't expect much.
& being a hatch & small its easy to park, about the only things I can think off.
https://www.sau.com.au/forums/topic/226384-hyundai-getz/#findComment-3987430
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
