Hi guys,
I thought i would check in with the pros just what people have done regarding security for their skylines. Im not neccessarily interested in alarm system but more other measures.
For example, how many people have put in a cut switch to the fuel pump??
What else do people do to stop would be theives?
Any one got pictures??
Im asking because im soon to purchase a 34 and would like to take some extra steps to keep my prize that little while longer.
Thanks everyone
https://www.sau.com.au/forums/topic/226677-skyline-security/
I don't leave it ANYWHERE. Seriously. I get edgy having it parked out the front of my house for more than 10 minutes.
im exactly the same. Always worrying about my car.
I have a mate with a nice alarm setup that has a few speakers inside the car set at deafining db levels so that any would be thief will well and truely be deaf before he gets the car started.
same here,buy a 2nd car. i got a cheap excel & work ute i take to shops and stuff.
At home its parked,coverd,immobilised,parts unplugged and or taken off and behind
the box trailer which is infront of the excel which is infront of mums camry which is blocked in
by my work ute,and the Line has a big tree 1 side and my house the other side and neighbours
fence behind.
GoodLuck!
Although I have an immobiliser/alarm I also use a steering wheel lock as a visual deterrent and leave nothing visible lying around inside.
yeah i club lock and alarm too and leave nothing to tempt people. hide my ebc and stuff. friends used to ask why i club lock even though i have an alarm, i always say its better to be safe than sorry. heck i even club lock my car if i park it in my driveway at night.
i pull the fuel pump fuse if i park in a dodgy car park with no attendant for the whole day.
so yeah
club lock
alarm
imobiliser
kill switch
cattle prod
Yup i have a 32 coupe and the gauge and shift light got stolen out of it in broad daylight, outside my house! Luckily it was only a rolling body at the time which makes me kinda stupid for having them in there anyway! lol
The build is nearing completion and ive been thinking about security too. Im considering the following.
-Alarm
-Fuel pump switch
-Steering lock
Was wondering if you could swithc the afm? Or having the ignition barrel as a dummy and using a hidden start button :P
Thanks everyone for the replies.
Some helpful comments there. So far i like the idea of the fuel cut switch, however i guess a determined thief could still hotwire any fuse that has been pulled, or ever a switch.
I was thinking of a dash / console mounted red toggle (removable) kill switch which would cut power to the fuel pump and anything else i thought necessary.
Interesting to see how paranoid some people are, something i should look forward to? :P
Im not the sort of person that would leave things in the car, nor likely to modify the interior with gadgets.
I also will have a club lock.
Thanks once again.
whats really sad is if they really wanted to steal your car they would....flat bed truck and all. Its those shit kickers that you try to deter.
a really good imobiliser and installation will generally do the trick. some guy went to the trouble of welding a box over the unit to the chassis..ha. the longer it will take the more risk it will be to the theif so he will move onto the next poor fella. unfortunately i find people just ignore alarms going off in general unless its damn annoying like if it was hooked to your horn then they would give a shit..ha something to think about.
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
