  • Replies 329
Steveo, as per our discussion in the middle of the night last friday!!
Am i taking your spot for Dave or completing a new one??? Needs to know so I can pay whoever and do the form!!
Yes you're taking mine :P
Yes you're taking mine ;)
ah okies... send me your bank details then puhlease... can't find em :)
Il get Dave to do the form this weekend..... still no idea which car!! Thinking mine though.... he's much funnier to watch in rwd mode :(
there's a great photo from 12 months ago of turismo's starlet going over that with 4 wheels off the ground ;)
Post up that picture!
Yeah, I never saw that photo, pic or ban :laugh:
farrkkk, how fast was he going?
110ish maybe quicker, didn't really look down, to busy concentrating on flight
thought of another noobie question....
is there a provision to change tyres from the rims down there coz i got some shitty rears in my garage with about 20-30% tread left on them and just incase i happen to get the ones currently on my car down to mettal, would i be able tochange the tyres without having to somehow bring the rims aswell???? if not the dosnt matter i'll just keep the smokeing to a minimum...
Nope, there's no tyre changing facilities down there unfortunately, unless you go to a wheel and tyre shop down there, and I doubt there'd be much open on a Sunday afternoon...
We want to avoid any unintentional skidding or spinning, and we're not allowing drifting or burnouts due to the rules of the facility itself, and we don't want another visit from the EPA for noise pollution either...
so does that mean the skid pan is going to be wet? coz if its dry my tyres will shred like no tomorrow and there will be heaps of noise...... and why does epa care? looking on google earth there doesnt seem to be any houses very near.....???
ps: id rather a wet skid pan anyway
Hey guys, just wondering how many spots are still available? I'm hoping to put the engine back into my GTR this weekend and would love to take it for a thrash if there are still spots available. It would be my first SAU event so it all sounds like awesome fun
There are still spots available :)
epa cares as theres a guy with a noise meter across the valley who rings them up as soon as it goes 1 db over the limit, and it will be the wet skidpan.
What a tosser... who doesnt like the sound of a car revving off its guts :)
Dang.. that was a quick responce boys!.. :laugh:
Thanks for the help..
Ill be confirming or not within the next few days..
And whats the CHEAPEST form accomodation that is NOT sleeping in the car.. Fixed back buckets are not comfortable to sleep in..
Edited by GTS4WD
    • Yeah the rule of thumb with an LS is 7psi per 1000rpm. That is decidedly not enough at 6800rpm. I mainly looked for the scenarios where knock started to be picked up and it was later in the session when things were hotter, and oil was thinner, and the pressure was lower than it should be. (i.e very horrible). I am hoping with thicker oil (I was running Penrite ten tenths 10-40, the manual specifies 10-30) that does not leak that it's much improved at that time!!! I am using Project Mu Club Racer CR pads. I'm also using the Project Mu 335C fluid. The symptoms imply that it was fluid that boiled, but no bubbles seemed pretty weird to me when I bled it today. I want to try Castrol SRF as it has a much higher wet temp but, well, I have new Project Mu fluid lol... so I should at least use that. The pedal on track was really noticable. It went from basically normal feeling to instantly near-floor. The car did pull up as before, it was just very much nearly at the floor before the brakes engaged. At that point I pretty much decided the day was very done, it did *kinda* come back during that very slow cooldown lap into the pits. Felt perfectly fine driving home.
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
