I think its the "A prestige touring wagon......." thing I have seen some people around here quote.
Someone should know!!
Nah - thats a sticker found on a lot of RS's something about a functional yet comfortable touring wagon.
Its like a set of mats I saw on ebay a while ago.
It had (stitched into the mats)
Pulsar
Feel the beat (lets drive) with more enjoyment as our feelings dictate.
They rocked, but some fool paid almost $400 for them and I didn't like them THAT much.
I really wanna know what it says now :/ I bet it was something damn funneh.
  • Replies 40
Mine is exactly as it appears in the sales brochure!
I did have P1 light weight wheels on it, but the R34 wheels went back on today due to the P1's cracking twice..
hey dude, you would happen to have those rear flares from the new set you got sitting around would you? wana sell em if you do?
D.
  • 2 months later...
No, I can see that bit, I was talking about this stuff.
Finally have an answer for you on this one, Mr Rooster. It says:
"Extremely outstanding specifications will lead you to the world of intoxication and help you relieve all emotions"
ROFL!
I would have preffered 'a prestige touring wagon that is comfortable yet functional' which is what i was thinking it was.
But that is just sweet haha
I think the whole car looks awesome - id even keep the stickers on it. Its a hell of a statement, the whole car is.
wats a drive meter? does that show your speed or sumthin or is it a tacho?
I had one in my car but i pulled it out and replaced it with a boost gauge, still got it in the garage somwhere. The drive meter is simply a tacho with digital display reading as in if your car is doing 3500rpm it reads 35 on the display and it has a colour display which as you go up in revs it goes up from green to orange to red and also has a shift light which conveiniently flashes at 3000rpm which is around when your turbo spools up. i dont think it can be adjusted though which is pretty poxy.
Headlights??
Sweet looking ride, uve done well there. id say thats a pretty rare car especialy having all those dayz options. keep hold of that one it will be worth alot one day. Mines has dayz options to but mine only came with front bar and rear lip and skirts, carbon instrument cluster backing, rear bagde. id like to order some other options if there available.
ROFL!
Oh lawd :(
That is farken GOLD!!
Here you go! If you want one with all carbon trim the same as mine.. Here it is..
http://cgi.ebay.com.au/2000-Nissan-Stagea-...A1%7C240%3A1318
Can someone tell me the part number for the Dayz front bar. Would like to see if it's cheaper buying new or getting mine repaired. Anywhere in Australia that makes the Dayz bar?
No one makes the Dayz bar! You'd have to find a second hand one if you can..
I would look at getting yours repaired.. I got hit from behind a few weeks ago and I am in the process of getting my one repaired as well.
Plenty of Dolphin kits come up in the ads if you wanted to get one of those..
Hornsby Nissan gave me this: "K60200V750 WHICH IS A FACTORY AERO ACCESSORY FRONT BAR COVER AND DOES NOT COME COLOUR CODED. LIST PRICE IS $2873.89"
You would have to check this yourself. unsure whether SI or II problem being I believe they are the same part number.
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
