  • Replies 131
one word
HACI'S
there is no better. ever.
cnr St George's rd and Bell St, opposite Bells St maccas. Look for two sweaty arab men in a caravan. I swear they must lace that shit with cocaine, cos I'm addicted as fuck to em.
If its not in a lebanese bread/pide then its not a kebab. GTFO with that pansy ass souvlaki shit.
https://www.sau.com.au/forums/topic/227871-kebabs/page/2/#findComment-4010915
one word
HACI'S
Respect.
They don’t taste as good these days in the newer caravan. They were heaps better when they were in the back of that truck and didn’t have access to running water in the truck. The mixture of uncleanliness and sweat dripping from them probably made them taste incredible back in the day. Although they still taste phenomenal.
https://www.sau.com.au/forums/topic/227871-kebabs/page/2/#findComment-4010998
Stalactites is hit and miss for a souva IMO.
The meat is really fatty and lots of crappy offcuts and grissle at times. I go there a fair bit cause @ 4am CBD when im working graveyards... not a lot open so i kinda have to live with it and take the gamble sometimes
https://www.sau.com.au/forums/topic/227871-kebabs/page/2/#findComment-4011078
i HATE the dodgy kebab joins that do the imitation meat, that stuff that looks more like shit than actual food!
Nobel's, greek place (keilor rd) do a good souva if your down that way, near la porchetta/chatreuse. Always pretty good with decent meat cuts
https://www.sau.com.au/forums/topic/227871-kebabs/page/2/#findComment-4011083
Nicks Souvlaki Bar (on lygon st near jive bar) back in the day was the bomb!! Wouldnt go anywhere but there.
And yeh Nobels on keilor rd dont make a bad souva either, I hate that compressed meat sh!t that some places use!!
https://www.sau.com.au/forums/topic/227871-kebabs/page/2/#findComment-4011286
farout wheres the westside kebab/souvlaki shops at man?!!
the exit just before the westgate bridge then turning left lead me to the tastiest souvlaki's i have ever tasted. frank was the guys name and was open till late
but few months ago was taken over by some other dude and haven't been there since.
brunswick street does have a few good kebab shops.
isn't there a place everyone likes on furlong road?
https://www.sau.com.au/forums/topic/227871-kebabs/page/2/#findComment-4011350
Ali's in Mitcham, it's ages away but still worth the drive!!
Haci's also when im in that area..
Lambs on Lygon Street and the one on Malvern road just off chapel.
man it's been a good 5 days since my last kebab im getting cravings!
https://www.sau.com.au/forums/topic/227871-kebabs/page/2/#findComment-4011490
I'm at a different site atm and they got kebabs for everyone from some place in Reservoir the other week.. I had no idea what I was eating but it didn't kill me so it must be alright haha.
Think that must have been my first kebab ever.. last time I had a souvlaki was years ago on Lygon St at some stupid hour of night.
Sydney's North Shore is pretty anti kebabs so never really got into them when I was growing up..
Meanwhile some of you are scary, I can't think of anything worse than those kebab caravans that are open at 4am. So never going to Bell St either... both sides of that corner are eyesores with the riced up lancers anyway haha.
https://www.sau.com.au/forums/topic/227871-kebabs/page/2/#findComment-4011800
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
