do you go to the one on malvern road, or the one on chapel itself? someone told me there is another 'lambs on chapel' on chapel st itself, the good ones on malvern road
**i might be making this up**
yeah just went to the malvern road one earlier tonight, wasnt as good as i hoped it would be, lots of ppl there so there was no time to cook the meat properlly. 5/10 this time. The other one ur takin bout is next to the chasers night club on chapel i think. Did any of you guyz make it down? thought i saw a black 33 with SAU stickers.
https://www.sau.com.au/forums/topic/227871-kebabs/page/7/#findComment-4642679
  • Replies 131
There are two Lambs on Malvern/Commercial Rd (same road, Chapel St divides them). One is right on the corner of Malvern Rd and Chapel St, the other is about 300 metres further up Commercial Rd towards the city. The one on the corner is shithouse IMO, you need to go to the one further up Commercial Rd. That said, Basti and Jezza thought it was just OK and they have proper Souvlakis...I usually just have mixed with cheese, barbeque sauce and chilli flakes so I'm not the best judge.
https://www.sau.com.au/forums/topic/227871-kebabs/page/7/#findComment-4643014
Kebabs are the worst. Can you say "big greasy cock full of e.coli"?
e.coli are gut bacteria. you asspirate. :P
I went to Jumbo kebabs on doncaster road today, next to where nandos is. Great kebabs. I recommend
Ali of Ali's kebebs owns that joint too
https://www.sau.com.au/forums/topic/227871-kebabs/page/7/#findComment-4644248
Kebab Box in Campbellfield was pretty good. The place is EXTREMELY clean, like a top notch restaurant clean. Impressive.
The kebab itself was pretty good, not very hot though, pretty tasty, but not as tasty as Ali's.
Attempt to find kebab better than Ali's failed :happy:
https://www.sau.com.au/forums/topic/227871-kebabs/page/7/#findComment-4644733
Nicks Souvlaki Bar (on lygon st near jive bar) back in the day was the bomb!! Wouldnt go anywhere but there.
And yeh Nobels on keilor rd dont make a bad souva either, I hate that compressed meat sh!t that some places use!!
thats the difference between kebab and souvlaki the meat and the foil.......
kebab=compressed meat (lik mince) and then toasted in the foil
souv=normal meat and then jus served without being cooked
also kebabs are usually halal, so it safe for the muslims rather than a souvz :)
https://www.sau.com.au/forums/topic/227871-kebabs/page/7/#findComment-4646390
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
