snowy was out on stage 1, looked like some mechanical issue since there was no obvious panel damage.
Kel and Pete made it home 8th overall, but it must have been a bad day for organisers - about half the stages skipped and a big roll on the first stage :P
Hey all,
What a start to my rally experience! 1st stage was a short non-timed warm up and all was well. 2nd stage was cancelled due to a Citroen being on it's lid which meant the massive 29km Geevston stage was to be my first timed stage. Despite all my talk of "taking it easy" etc we pretty much were cracking it from the get go. That was shown by the fact we were apparently the 2nd highest clocked speed through a speed trap early on in the stage.
Everything was going great and I felt really comfortable with the speeds and the car until around the 17km mark when I noticed the car was getting hot (water had hit 120degs) so I was forced to go up a gear and try and rely on corner speed. That was still going ok (and the temps were coming down) until the front right wheel fell off....
All 5 studs were completely sheared off - NFI why - but needless to say it brought us to a stop. Amazingly however other than the hub / rotor edge / inside of the wheel there isn't a single mark on the car. We made a couple of calls and found someone with some parts and the good news is we are back to fight another day! Fingers crossed we have a better run tomorrow.
Untill then.... :)
too tired to post properly but it was an awesome
day out - even with all the stage changes
shame some of the stages downgraded or cancelled were ones better suited to the skylines :)
Very sad to see Snowy parked at the side of what turned out to be our first competitive stage hope you guys get back out tomorrow
Will be interesting to see how tomorrows adventures on the goat tracks go :P
Andrew its probably too late now but most likely youv've just learned how much harder targa events are on the car than track. I would guess that the hub ring on your rotors does not match the ring on the wheels you are using.
the studs themselves are only to hold the wheel on the hub, not to hold the whole car to the tyre. the inside of the hub should be a snug fit on the lip of the rotor. If not you should sort out some hub locators for future.
all the best getting it sorted tomorrow.
Kel...go to sleep! You have a pet food car to catch :)
At least it wasn't a $2 part - studs are about $5 each aren't they? :)
Great to see that you can get going again tomorrow - well done guys.
Any word on what happened to Stephen Bradford?
Regards
Andrew
Hey all,
Untill then.... :P
Just saw that Snowy and James are out with mechanical problem before the start of the first stage today.
*edit* sav_man beat me to the punch *edit*
Edited by PHaT MR30
Umm why are those marks heading off the road?
Oh...I see.
Apparently it was only a minor fire too.
Tassies finest tow trucks to the rescue
Doesn't look to bad here....but I think there might be unpleasant surprises under the bodywork.
Anyway apparently they are both
but I think probably sore tomorrow. I guess Kel should have invested in a HANS before going out in the r35.....
Apparently poor road surface and a little too fast....just a little off.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
