I think in the end he just decided against it because he reckons he just needed 4 paw power for when it is wet.
His final options were a 997TT, R35 and the TT-RS. He was always most keen for the RS - just because it was different - but he'd always been concerned over the fact the the engine hangs so far over the front wheels.
But apparently he took it for a spritted drive last night and is mightly impressed with it out of the box so we'll just have to wait and see I guess.
I'm going to be interested to see how this runs in Tassie this year! He gets to run it as M2 (LMS) regs as well so it will be interesting to see just how well it performs. If you don't know who it belongs to the plates help give it away! *Hint - he used to drive a Black Porka...fast :)
Can't wait to hear this thing, love the sound of a 5 pot
Joisus! Whats the scoop? lol
I had to do a couple of little mods to shift the car from Z Tune Spec to N1 spec (basically so I could run in Early Modern rather than R35 fodder class).
This basically included changing the exhaust over to a 3" system and putting on some N1 spec turbo's. Only when we got to the turbo' we discovered the water lines were infact being oil lines. A quick inspection of the radiator showed it too was pretending to be an oil cooler.
So the engine had to come out and be inspected. The head gasket looks ok so we "presume" its a cracked head. But I can't be 100% sure so since there was a spare N1 engine laying around we've chucked that in instead now. So fingers crossed we get it sorted out by the weekend. The MCA's aren't looking likely to be ready though which sucks. But they've just had one issue after another!
did you have to modify things to fit the mca's?
looks like Garwood might not be back to defend his wrest point crown at this point in time.
Edited by sav man
Haha - yeah Handbags sent me through some pics. Your guys engine looks a LOT more busted than mine did LOL And you have less time to fix it. Plus you have to respray the car from the fire!
You were riding shotgun at the time right? What was the call? Right 6 into Left 5, 100, Engine Failure into Fire Ball into Immediate Lots of Swearing? :)
Good luck with it all though. Team Last Minute FTW!
Yeah I was riding shotgun. Hadn't called anything...was enjoying the ride. Must have been very hot back there and by all accounts the fireball out the back was massive!
We're on the boat next Wednesday night so we have 8 days. Fingers crossed the car will be ready for a dyno run Monday and a run around Winton on Aus Day. Plenty of time!!!! :banana:
Will be watching intently all you guys on the interweb :P
Timmy and I made the call yesterday, no Targa Taz 2010 for us :P
Hopefully we'll get together for a couple of shorter events though, Mt Stuart being one, it's a good little relaxing event :P
Sorry to hear it Benny - but I can fully understand it. I'm struggling to find the time to do it this year as well and to be honest if I didn't have the free entry I'd be thinking twice. It's such a big commitment of time (and $$$ obviously). I worked out the other day that the bare minumum I can do the event in time wise is around 13 days in Tassie. Plus all the other shite back home. It's a killer!
But the good news for you is there is there is a rumour that there is going to be a cracking new short event (2 days) in November on the mainland. One day Stu might man up and actually tell everyone all about it :P
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
