Good luck Liam! Hope you have a bit of fun and make some good times :banana:
Thanks Kel! I'll post up some video if all goes wel
Oh awesome...Will come and say Hi :3some:
I so cant wait...need my rally fix!! Rally School just isn't enough!! :cheers::laugh:
Sounds like it will be an interesting experience for the both of us!
Maybe Jeff :(
Update your sig mate, I see you've entered old faithful ;) Unless of course you're going to *BAM!* suprise everyone at the last minute and unveil your 35 all caged up :worship:
no it's the 34 again
just can't bring myself to stuff up such a nice "road car" with a cage
I didn't know anyone read sigs!
Alright, we're 3 days out from Lake Mountain and there's no talk...
We've had the car re-tuned, had the suspension tickled with and have a new set of Yokohama shoes.
Looking forward to the weekend and the weather looks ok...24ish on Sat and 20 with poss showers on Sunday. Adam is looking forward to running in the wet...not sure if thats good, or bad :blush:
oh well i decided not to run rookie, as i didn't have the monies to do it, and no incentive after the possable free entry to Targa was taken away.
just have to join the local circuit series 3 rounds in, and get the car setup for next year. Which i'm guessing will be a 6 day event for the 20th aniversary.
Looking forward to the weekend and the weather looks ok...24ish on Sat and 20 with poss showers on Sunday. Adam is looking forward to running in the wet...not sure if thats good, or bad :(
I'm so freaking excited!! :P Been razzing my team mates already!!
Jumping in the hummer tommorrow after work and travelling down to invade Victoria! Cant Wait :P
Make sure you come say Hi Rexdan if I dont see you first!!! :bunny:
Looking forward to the weekend and the weather looks ok...24ish on Sat and 20 with poss showers on Sunday. Adam is looking forward to running in the wet...not sure if thats good, or bad :bunny:
Im sure your all up on it, but this is what i think of when the name Adam Newton and wet are added together.
Its amazing how much that car has changed, they day after that footage I won a comp to go for an extreme ride with him arround symmons plains, and then only a hand full of laps later he ripped the rear quarter off it on the pit exit armco!
So we had an interesting weekend.
Seems the dreaded cold tyres/turn 1 curse was out and about over the weekend.
We started off with an uneventful 4:45 and spent the rest of the weekend trying to match and better that time. Stage 2 saw us massively sideways, rear end in a ditch, rear bumper torn off and right rear alignment shot to pieces...all on turn 1. Despite this we still managed a sub 5 min stage time and all we lost was the rear bumper and a little shine off the car! A spin at turn 3 later on in the day saw a 4:57 before the rally gods allowed some form of speed and we finished Saturday off with a 4:43 on Stage 6.
Adam took the car back to Techsport for a rear alignment that evening while i found some accomodation and the biggest parma i have ever seen.
Sunday saw a much more consistent effort with the only thing effecting our times a damaged Porsche(with oil everywhere) and a little bit of drizzle that we backed off for to ensure a finish.
The final stage 10 started off well and only got better as we blitzed the 9.3kms, smashing our previos best by 5 seconds to end the weekend with a 4:37.7. Good enough to be the 4th quickest on that stage.
Results saw us 6th outright, with a 1st in class, a great lead-in to Targa Rookie in a month.
Was fantastic to catch up with everyone and Jess, Burgo's R looks a heap of fun :-)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
