Here is the second last run up. rear tyres had totally delaminated from abuse, I could literally pull long trips of rubber off them exposing the canvas.
was very loose in the bum, and had a couple of little moments, mostly later in the stage. One at 2:40 was particularly memorable, because it could easily have been a sheer drop or a Gum, yet Tim the loon was giggling. haha
You are punting that car SOOOOO hard. Max cudos. Are you still running the Apexi suspension and GTR brakes?
Just contact the guys at the booking centre (http://www.mansfieldmtbuller.com.au/), maybe pick up the phone and have a chat. They have access to all the accomodation in the area and can put you in the location and price range you need.
Personally I'd just spend the entire period on the Mountain for recce and the weekend, remember we will be competing up and down (part) of the hill so extra reece ops at the start and end of the day.
I was up their yesterday and plenty of accomodation available still I'm told.
Batten's car seemed to come up Ok on the scales... pretty light machine anyway I understand.
Alloy cage is still permitted as it was a pre-excisitng structure... not ideal, but it's their choice.
THC roads are plenty wide enough to thread a GTS-t past slow GT-R's Woostar!
When i need a nav I am going to charm the local rippers and see if i cant at least get a lass who really knows the true meaning of servicing during a rally!
Don't laugh, you'd be surprised how many plastic surgeons and the like that turn up to these things with hookers :/
looks basic for now, but going forward every part of your entry for octagon events can be managed online via an airline style databasing system behind that site... this new system brings an end to filling out those endless paper forms and allows for much much more!
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
