i still find the best way to bleed the things is on a hoist, wheels in the air. Bleed them at the nipple on the transfer while someone's in the car creating a "wheelspin" situation.... if you know what I mean?
i just unplug the bleed wire in the RH kick panel, and let the pump pulse with someone in the boot tipping
oil in, while i crack thre bleed nipple on the transfer
but then again most GTR transfer's need a good rebuild by this point in there life,
when we measured up my spare box it needed 90 thou worth of shim's to get it back
to almost factory spec..
We spent the last 3 days down in the area for our recce. Course looks very interesting, plenty of fast long corners :D
The dirt section between Jamieson and Big River seems to have been graded all the way through now and is fairly smooth with no holes etc... There is a lot of small, loose gravel on the top though which will bury themselves into our tyres.
How does everyone plan to clean out their tyres? We were thinking of taking an ice scraper style thing and a screw driver to clean as much as we can out of the tyres, that's if there is enough time before the start of the next stage.
Don't worry about it...It's exactly the same as the Pelverata Stage at TWP- straight off the stage and onto the gravel road, you will find all the rocks will clear themselves as soon as you get back on the tarmac.
We are leaving this Sunday, really looking forward to it!
I'm sure this has already been covered somewhere, but can anyone confirm the bowsers with 98 for Targa High Country? I"m going to sign up with race Fuels as a backup, but I'd like to fill from the bowser as much as possible.
Mark
Mark
The BP on the Mt Buller Rd in Mansfield has 98. We pass it Friday for prologue, Saturday morning after Mirimbah and Saturday arvo prior to Mt Buller...hope they have big tanks!!!
Sunday we're clean outta luck!
(oh and from memory the Caltex on the main st of Mansfield has Vortex 98 as well)
Hope that helps :P
What's the official/legal ruling on carrying fuel. I know we had the warning about being safe, but there was no clear cut definition of what is considered safe, and more to the point, what is legal.
The only ruling I can find is that there is a maximum of 250L allowed per passenger vehicle, but no definition on how it is to be carried.
Hope you're not contemplating working in control....or have the head games started already? :P
Ooooppppssss yeah won't be doing that *reads over regs again...
The Caltex at Eildon has 98 too, not sure how 'fresh' it would be though as it is not really the middle of anywhere...
Has anyone got the latest High Country GPS kmz file? The one I have is from Sep 21, and I can't seem to find the link for the file anymore.
I just emailed it to you.
Edited by marinetowing
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
