They are a good handling car (for their weight) Im sure with all the luxo stuff pulled out they wouldnt be all the heavy.
Edit - 1750kg in road going form
and a tasty pic
Another edit - the Group A Jags weighed in at ~1400kg
So similar weight to the Commodores/Mustangs/Falcons/Camaros etc that would run at targa
Yeah Timmy's right. You've been able to put 100m guards on MS cars for years. Not 100% sure if the proper Group C guards on RX-7 are within 100mm, but I understand the Commodore Group C guards are slightly more, so to get the right period look for these cars the rule will be expanded to say something like 100m, or those used in regonised championships are acceptable... this will overcome the issue with some other cars currently doing this anyway.
You can already run the front bumper and wing under the aero rule.
They aren't that bad, here is a clip of my mates IP RX7 at Bathurst
Why the F@#k can't you embed?
the RX7 in front doesn't seem to have any issues with torque... it just frys them off the line!
so many good ideas in the last couple of pages but be honest... you'll all end up in Emos :laugh:
I've been talking to damo about it for a couple of years. He thinks it's dumb, but I think a XJS (with a lot of work) would make a very compeditive classic. Weight is the big problem though
but seriously..... who wants to be caught in a Jaaaaaaag.........under 50?
let alone modify one.....
look @ ur link - youtu.BE, make sure it's proper link and it works automatically.
youtube been producing odd links lately :(
An XJS ran in 94/95ish era. Most memorable thing, sparks and flames flying out of the wheel spokes at the hairpin at Symonds......after 1 lap. Must have done a fair bit of field and fence work during the afternoon stages - day 4. Don't think it was a good year for British racing green, 2 tonne pussy requiring some overnight heroics at Burnie too, if I'm remembering my years.
There is a bloke locally who has all the tricky bits after being Jag driver of the year worldwide and given boxes of parts, he''d want Gallardo money for them though, if you that attached to oil leaks.
To set the cat among the pigeons, an 037 Lancia looks like it can run classic in SS :rofl2:. One that was out here in the early 80s and failed to find money to run in the ARC, returned a year or two back too.
Maybe it's time I pulled the"Two Ton Pussy" out of retirement and ran it again
I was disappointed you didn't dust it off this year!
I just got the RX-7 back from the bodyworks and had forgotten just how high SP wings were... years ahead of their time in shopping trolley design!... but I reckon the SX-R would give it a run Jeff?!
Edited by t01-100
Not a dry sump no. You can modify the standard sump with traps/gates and/or increase it's volume it to reduce surge
There has previously been a R32 running in the Demo Class (non-competitve) that more than likely did run one.
82. Sump / Oil Filter (except Showroom)
The removable section of the sump maybe modified to increase capacity and internal baffles may be fitted. Sump pickups maybe modified to allow for modified
sump depth. The oil filter element/cartridge/s is free, providing the cartridge fits without modification and does not perform any function other than filtering the oil.
modify the pickup and put gates in the sump and a GT-R will be fine. Our R33 GT-R did 5 Targa's, 2-3 3 day rallys, Eastern Creek 6 hear, and a heap of club day work with no engine problems. When we pulled it out for a check, it had only slightly marked bearing #6
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
