I've had 2 DNF's @ Targa. One was a wheel falling off and the other was a snapped upper control arm. Both were most likely from old tired parts.
I've had other issues in the past with electrics and not at Targa but broken front diffs from launching the car. (So I consequently switched to a Nismo front with the extra set of spider gears for strength)
This year there were also a number of RB26 engine failures. But I think if you make sure your cooling is right, you have a nice baffled sump, and don't get too greedy with power (I run around 330kw's @ wheels) the engines should be ok.
most common downfalls of the 32/33/34 gtr's at targa? (assume the car is relatively well built with bigger brakes, suspension etc etc)
keen to know what fails first.
There's no special requirement over a hard driven track day car, just build and tune the car with the fact that it needs to keep going without fail for 5 and a half days of competition.
So, the biggest issue is the RB26, you must keep them cool, we've found they last much longer if they run cool, 78-80 degrees, and yes, keep the power to around a genuine 330AWKW. All the obvious oil control issues need to be taken care of too.
Coils are also a constant concern, fresh ones help alleviate any concerns.
Chassis wise, make sure your wheel bearings are good, brake knock off is a serios consideration on rough roads with big rotors, and springs behind the caliper pistons are required to help eliminate it. Otherwise as you know the driveltrain is strong.
A solid sump gaurd is also something I'd recommend.
Greg Garwood is looking for a good tarmac prepped R32 GTR if anyone knows of one?
Yes, I've told him about Jurgenson's and I'm sure he'll follow that up. - edit - Drew doesn't wish to sell now.
Well he is today, who knows what he'll want tomorrow.
The Nav's are the best to answer that....but I'm willing to bet a good GPS should replace the olde fashioned tripe computers....
Yeah I ditched the the terratrip in favor of one of these. It did the trick ok but still not perfect - someone will come out with a good proper GPS based one in the future I'm sure.
IMO, an accurate distance meter is still worthwhile, for times when you come across a car and need to report an acurate distance into the stage for that, or if you have hazards reported on stage, especially if there's multiple hazards. Yes, I know most of us write them onto the notes using the note's distance graduations as a guide when they're reported at the start line, but it's still nice to have an accurate distance to confirm.
I guess someone could confirm all the features of the GPS thingy that was provided at Targa....but I thought one of the features was GPS location of offs.
Extremely good idea i think
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
