I've had 2 DNF's @ Targa. One was a wheel falling off and the other was a snapped upper control arm. Both were most likely from old tired parts.
I've had other issues in the past with electrics and not at Targa but broken front diffs from launching the car. (So I consequently switched to a Nismo front with the extra set of spider gears for strength)
This year there were also a number of RB26 engine failures. But I think if you make sure your cooling is right, you have a nice baffled sump, and don't get too greedy with power (I run around 330kw's @ wheels) the engines should be ok.
most common downfalls of the 32/33/34 gtr's at targa? (assume the car is relatively well built with bigger brakes, suspension etc etc)
keen to know what fails first.
There's no special requirement over a hard driven track day car, just build and tune the car with the fact that it needs to keep going without fail for 5 and a half days of competition.
So, the biggest issue is the RB26, you must keep them cool, we've found they last much longer if they run cool, 78-80 degrees, and yes, keep the power to around a genuine 330AWKW. All the obvious oil control issues need to be taken care of too.
Coils are also a constant concern, fresh ones help alleviate any concerns.
Chassis wise, make sure your wheel bearings are good, brake knock off is a serios consideration on rough roads with big rotors, and springs behind the caliper pistons are required to help eliminate it. Otherwise as you know the driveltrain is strong.
A solid sump gaurd is also something I'd recommend.
Greg Garwood is looking for a good tarmac prepped R32 GTR if anyone knows of one?
Yes, I've told him about Jurgenson's and I'm sure he'll follow that up. - edit - Drew doesn't wish to sell now.
Well he is today, who knows what he'll want tomorrow.
The Nav's are the best to answer that....but I'm willing to bet a good GPS should replace the olde fashioned tripe computers....
Yeah I ditched the the terratrip in favor of one of these. It did the trick ok but still not perfect - someone will come out with a good proper GPS based one in the future I'm sure.
IMO, an accurate distance meter is still worthwhile, for times when you come across a car and need to report an acurate distance into the stage for that, or if you have hazards reported on stage, especially if there's multiple hazards. Yes, I know most of us write them onto the notes using the note's distance graduations as a guide when they're reported at the start line, but it's still nice to have an accurate distance to confirm.
I guess someone could confirm all the features of the GPS thingy that was provided at Targa....but I thought one of the features was GPS location of offs.
Extremely good idea i think
    • 2001 BE5D Subaru Legacy B4 RSK (3rd gen) EJ208 (pink injector) Twin Turbo 280PS 5-speed manual Full time 4WD "RSK" grade which means all of the above LQC option which means stock rear spoiler  I got it primarily to export to someone outside Japan who was interested. These BE5 Legacy B4 RSKs are going through a bit of a resurgence right know in Japan as they are one of the few cars from the "turbo, manual, RWD/4WD, 280hp gentleman's agreement era" cars that don't require stupid money to purchase. Which for some people might be a good opportunity to get as a base for restoration. If I can't find anyone to purchase it I will certainly be doing that myself over the long term. Why? Because it's properly fast in stock form, handles well enough for a GT sedan, there's still enough aftermarket and (if you can wait a while) genuine part support to make it a restoration candidate (<-- that will only get worse over time so it's a case of do it now or choose get a BL5 4th Gen). Mechanically it's fine, has only 89,200kms on the odometer. The problem with this car is that the body and exterior trims are weathered from at least the last 10 years being parked outdoors. I'm the 3rd owner, the first owner was the one that had it for 14 years and barely drove it, had a low-speed front impact (which didn't damage anything behind the radiator support) and got it fixed and sold it. The 2nd owner put most of the kms on it and parked it outside for the last 10 years, hence the door rubbers have seen better days but if you overlook those cosmetic details, it presents pretty nicely. There is some minor rust on the LH rear wheel arch which I'll have looked at too at some stage.  Also as you'd expect from a car this age, the clear top coat is gone, leaving a satin finish on the roof.  Mechanically it's fine (as you would expect from a car with less than 100K kms) but the steering does feel slightly vague around the centre position at higher speeds. So first on the list is to get the steering rack bushes looked at. There's also the Lock button on the remote which doesn't work, but the Open button does.... it means that the anti-theft system thinks it's always open? It seems like if you open the car and don't start the engine within 3 mins or so the anti-theft kicks in again without any beeps or signals. So if you got to start it after that, it won't. You have to push the open button again. That's how I understand it anyway. Just a small irritation but not a big problem to sort out. There's only one mod, the Wangan SPL muffler. Just a tad louder than stock. It's a really good mod for those who don't want to wake the neighbours but still want to hear a more prominent unequal length header EJ20 sound. Anyway I hope to get all those things done eventually, that is unless someone wanted to import it to their country from Japan (where I live). I'm open for negotiations as I really would like a Skyline... but this will definitely suffice in the meantime 🙂 *Disclaimer: This is how I picked it up from the dealer, minus the stuff on the back seat. I haven't cleaned the engine bay or done a thorough exterior clean, aside from spray painting the wipers.
    • Wow, even with the Audi logo centre caps. I love OEM wheel mismatches.
    • Welcome!  Can't go wrong with a Stag.
    • Looks good. Nice height.
    • Hey all, a little help from the Stagea hive mind plz.. I'm days away from buying either a 2002 Stagea 250tRS AR-X Four, premium leather, power seats and all the old switches etc that go with it, or a 2002 Stagea 250tRS VR-X Four AERO, pov pack, cloth seats etc, with coil overs, sports zorst, comes with original zorst and suspension and parts. (I think I've got the models right?) Both are VQ25DET, have 160000kms, both straight no rust both with $2000+ in recent servicing receipts, both ride on aftermarket 18" rims. The Aero has a replaced turbo as well. I like the cool factor of the Aero car but the AR-X has never been modified. Neither have been driven hardly at all in the last 5 years. Any thoughts on which one or does it come down to personal preference? davemoto
