With a Z31 couldn't you run it as a 200ZR with an RB20 (silvertop conversion with redtop covers if you have too), thus bringing the costs back to 32 levels but with an earlier build date ...
Edited by MacGillaZ
831 Early Modern Jeff Beable Nerida Beable 8 LMS C 2000 Nissan Skyline GT-R V-Spec N1
847 Early Modern Liam Howarth Larry Howarth 8 LMS C 1995 Nissan Skyline GT- R V-Spec
Looks like two mainlander SAU'ers to me
Progress for us is coming along, tech adviser from Renault UK was in over the weekend :P . Pogo's and extra wheels arrive end of this week.
Waiting to see if I am actually going to get a new race suit out of the french outfit....
How goes Savman's progress???
So Tuggah isnt far away now. No news on who is actually running from SAU? Seems only the Tassie lads are running
That would be Dad and I. Car's all set to go and with 8 fresh A050 Ms as of last weekend. Flying down next weekend (30th - 1st) for recee, hopefully the notes arrive before then! Fair to say i'm f'ing excited for it!
I'm hoping to make it down to Hobart for a beer!
:cheers:
Me too!
If I can swing it I'm coming down to fish a tournament with Mozz and the lads on the Double Black on Friday, Saturday, Sunday, and see everyone at the Tugga Bar on Sunday night!
Only thing holding me back from booking the flights is I stupidly signed contracts for a bloody property settlement on the following monday! Grrrrr, IDIOT!
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
