Hey, i'm just in the middle of converting my stagea s2 to a gtr. I picked up a half-cut, rear k-frame and diff from an R32 GTR. At the moment, both motors are on the floor and we have started transferring and modifying. Just wondering if anyone has done this sorta swap before, and has any useful advice, or knows what problems they had and how they overcame them?
https://www.sau.com.au/forums/topic/228611-stagea-gtr-conversion/
There is a bit of a DIY section here. It has been done before.
http://www.skylinesaustralia.com/forums/Rb...al-t106465.html
I have only done a auto to manual conversion and 34 gtr front end, but not motor.I still have the rb25 in mine. I did consider the motor at one stage when a 260RS front cut and rear end was offered to me at a good price.
Yeh, we are a little concerned about the ECU, but we unplugged the stagea ECU and all the accessories and stuff seem to work still, so we were hoping to use the R32 ECU with a modified loom, and hope for the best. Will this work? The ATTESA system, how will this be affected?
Dude, I don't claim to be an expert, but its my understanding that the R32 ATESSA system and the stagea ATESSA system (based on the R33) are poles apart - you can't just pull a fuse to run in RWD like you can in a 32 (and there are people on here who have the destroyed clutch packs from the transfer case to prove it)
When you say "everything" works, I assume you are talking about the body? (doors, windows etc)
Wouldn't you be better off with an aftermarket system?
Attesa has its own computer, seperate to the engine ecu. I think it will need some feeds form the ecu
Talk to Brad, user name unquie1, his old user name is cruiseliner, the guy who wrote the diy section
He has done it all before.
Mine was done in the same way, but with R33 parts, and a power fc. Al work was performed by Herman, at envy imports in Brookvale, NSW. Give him a bell, if needs be: not sure what the differences are using R32 parts, but I understand they are substantial...?
ive done it and its pretty simple ask away and ill answer best i can, i did it 3 years ago now so my memory isnt the best to list everything off the top of my head
i ran an aftermarket ecu in mine (autronic) so wiring wasnt as difficult as the stock gtr loom. Im about to put a pfc in the car so i have to wire in the gtr loom myself and i remember trying it a while ago and it was a real headf**k lol, if u happen to find anything out post it here and ill be happy to help u anyway i can on the mechanical side of things.
ive also done the r32 gtr diff/axles/unis into rs4 stagea too and its also a long winded process.
http://www.skylinesaustralia.com/forums/Gt...amp;hl=gtr+diff
the attessa ecu in the rear of the car requires a tps signal from the engine ecu loom
Edited by unique1
Firstly, let me wish you a welcome to SkylinesAustralia, and to the Stagea section of these fine forums! :) I'm not sure how long you've had your Stagea, but I'm pretty certain that it will bring you plenty of enjoyment.
There you go, Brad is probably THE man to talk to in regards to this as far as the owner-experience goes.
Whereabouts in Australia are you? If you let us know this, we can probably help point you in the right direction in regards to who else to speak to, where to get parts from, and I'm sure there'll be at least a few people who can probably help in the process of the conversion.
  • 3 months later...
sorry to thread steal, but a friend of mine wants to convert an auto stag to rb26 manual and he wants to know about the attesa.
if he gets a r32 front cut and uses the r32 gearbox, transfer case and attessa computer will the attessa work the same as the r32 gtr(as in fuse out= rwd powersliding fun)????? or will he need to change the pumps and some other stuff???? any help would be great
cheers
cheers
it will still work like a r33/34 gtr if u run a 32 tf case and box, its the pumps etc that preload the clutch packs unlike the 32 one which doesnt, allowing fuse pulling as a safe method. I'd be guessing but i'd say the 33/34 setup would retain some sort of one way valve to stop the fluid returning back to the pump when its off and therefore allowing quicker transition into 4wd when its needed, unlike the 32 which has to start fluid from the pump again and thats a delay pushing it through the lines. Dont qoute me on that bit its just the understanding i have of it.
so it is as i suspected, he'd have to replace the entire attessa system.
out of curiousity if the one way valve was removed wouldnt it that mean u could then remove the fuse and not damage the attessa?? or if u replaced the 33 type pump with a 32 type pump maybe??
this attessa stuff is way beyond my feeble brain
you might be able to use the r32 pump to run the stage but it really is a downgrade - the stagea/r33 style reacts significantly quicker and has a better balance.
If all you want is a rwd stagea just remove the front driveshaft - only takes about 15 min (or 2 min if you have a hoist lol)
I have a 32 gtr transfer case and it definately still reacts like a 33 system, so the smarts are in the pump and/or attessa computer neither of which will come in a half cut
cheers for that duncan
my mate was thinking more of a drag application. u know flick over to 2wd for the burnout then back to 4wd for the run. plus he's mad keen on skids. i think he should just get an r32 and be done with it.
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
